I was following NGK's american website recommendation for the torque for a 14 mm thread (that's what our plugs are). The site said 18-21 foot pounds.
Normally, I just hand tighten it, then go another 2/3 turns. I normally just use a short 3/8 drive ratchet, so it's pretty hard to overtorque it, because you can't put my torque on it anyways.
Today, I was borrowing my friend's torque wrench, so I thought i'd torque them. Mind you, that wrench, is one of those $10 ones from supercheap auto, so I don't trust the reading. It is a 1/2" drive one like 30 cm long, so it'd be possible to easily overtorque it.
Anyways, I kept turning until about 1 full revolution past hand tight.
1. for those of you who have also used a torque wrench, did you also find that to get the correct torque, you had to go almost 1 full revolution? or have I f**ked it and tightened it too much?
3. For those of you who have engine building experience, or those of you who know about how far the piston comes up, do you think that the spark plug will be sitting too low down in the combustion chamber, and will the piston touch it?
Edited by MANWHORE
https://www.sau.com.au/forums/topic/162782-spark-plug-torque/
plugs are done by feel... with a spark plug socket + extention bar thread them in finger tight, then use the ratchet to tighten them 1 full revolution, never any more.
best to err on the too loose side then too tight.
and no, having the plugs too tight will not make the plug come in contact with the piston, it will on the other hand give you drama;'s when it comes to take the plug out with it possibly snapping the ceramic section off in the head.
As Simon said it's mostly a "feel" thing with plugs & be v-careful with over-tightening 'cos you run the real risk, esp with an alloy head, of pulling the thread & whilst you can sometimes do a dodgy repair in-car it's usually a head off proposition to fix properly
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
