if you set it to 15, according to the crank and the copmputer is telling you it's 15, then the timming is way off.
If it runs like crap at 15, i sugest the timing is out a toth or two.
Sometimes too, the key on the harmonic balancer brakes, and the referances are all screrwed up, so 15 is actualy 40 or somethign stupid.
As you stand in front of the engine bay and stare down on the crank pulley, the timing marks move from left to right (in LHD, that's from passenger side to driver side). So the first mark you see is 30 BTDC, then 5 deg decrements to 0 (TDC). (Note - 15 BTDC is the same mark, regardless of which end of the marks you start from)
I have observed that some timing lights "double" the reading, so to get 15 BTDC actual, you need to set it up at 30 BTDC.
you could double loop the wire OR only clip on one side of the timing light (i.e. dont clip it), if yours is the kind that springs then as cubes said just double loop it.
and mine goes to FULL boost on neutral. but its an auto and timing is at 20deg on autos. may have something to do with that.
UPDATE !!!!
Today I pulled the front cover off.
I set the crank to TDC (top dead center)
Both Cam gears lined up with the marks
The timing belt did have some flop to it
instead of just adjusting the tension more
I will be replacing the belt with an aftermarket on (such as the Greddy belt)
I also removed the Cam/Rocker cover's
And the cams are just fine.
So new timing belt is going on this weekend, putting it all back together.
But I still think its going to make boost...
Any other ideas?
I spoke to a couple of my buddies who have high horse power cars (knowledgeable)
and they said its ok normal to see the turbo boost some on no load. but it will boost more on a load...
but then I speak to other ppl who say there car doesn't make 1psi when up rev it all the way to the revlimter
UPDATE !!!!
Any other ideas?
have you tried to change your cas over with another one just to try and take it out of the equation? It could be a dodgy cas giving it wrong timing. What about the boost gauge, have you tried to use one of your mates? It could just be a dodgy gauge aswell??
I havent seen the footage, but at idle does the turbo actually sould like its spooling, or is it quite? Im in the middle of putting a n/a sr20 with a bolted on turbo in a mates s14, and we had the timing way too retarded and it was hitting boost at idle, but you could hear the turbo spooling, and when you turned it off, the turbo fluttered like as if you were driving and backed off on the accelerator. Does the turbo compressor surge or "flutter" when you turn the motor off.
Turbos need load to get boost, or an antilag system. When you flatten the accelerator in neurtal, your creating some load on the motor, not as much as normal driving, but still theres enough load to create some boost. Theres no way of getting boost at idle without antilag, for the simple reason that there isnt enough load.
Theres two common antilag systems. The first is aggressive air injection, and the second works off igntion timing. So if anybody is definately getting boost at idle, and you will be able to hear the turbo spool, i would say its timing related.
so explain to me how my car is at 20deg and making full boost (12psi) at idle.
Being that I am in the USA, it is not easy to try another CAS.
But I do think the CAS from a Q45 is the same as the RB25.
I did not get to try another boost gauge.
As soon as I got to the garage I took to belt cover off
And since I decided to replace the belt, I began removing it.
So until I get the new timing belt, the motor is disabled.
Once I get it back together, I am going to fire it up again, and try another gauge.
If I set the timing to anything below 10* I can begin to hear the turbo spool
but at 15* its fine. and when I rev it up.. and it makes boost. I can see my piping couplers expand due to boost
So I know its making some sort of boost.
I would really appreciated, if people try it out on there car and let me know how it turns out.
if also want to buy the Consult to hook up to my car, so if can see engine statistics
to better determined what is going on with the engine
Power Enterprise belt installed
Timing on point
I am now waiting for some other new parts i ordered
Like new Radiator, Fans and Cooling panel
Once that gets here ill start it back up and see how things turn out.
An other thing id like to mention is...
being that i have the Greddy IM and Q45 Throttle body, larger IC piping and a bigger FMIC With the Stock T3.
Do you think since there is alot more Air passing though the motor now that it would have enough load to spin that little turbo?
Well updates to come !!!
depends on what set-up you have. If its a stock motor/turbo, idleing at the stock 650rpm with the timing set at 20degrees btdc i dont believe there is anyway you are making 12psi at idle, you will definately be hitting some sort of boost while free-reving but even then you shouldnt be hitting full boost. Like i said before, people can choose an antilag system where the timing is not affected, but that requires air injection which is extremely hard on the turbo. Even the other method by retarding the timing to achieve boost at idle is still very hard on the turbo, and will shorten the life massively. Most turbo motors should be able to hit some sort of boost by free-reving the motor in neutral, but that only because by flattening the accelerator till high revs or limiter is putting the motor under load, try do that only half throttle to limiter and see what boost your getting, you wont get any because no load..
turbos cant just make boost, they need certain factors to be present to do it
Edited by R34GTFOUR
Timing on point
even with a bigger manifold, intercooler, throttle body etc, at idle it shouldnt be sucking anymore air than before because that is all governed by the throttle body's butterfly. If the clearance was wrong on the throttle body and it was sucking too much air, then you would just have a high idle and we know rpm doesnt create boost, but load. It could idle at 4000rpm, but with no load, it wont boost.
Once you put everything back together, check the timing, then check it again, and have it set around 15degrees and get another boost gauge and see what happens. It has to be a timing issue, or its just the gauge.
An easy way to check if its running boost if you cant get another gauge, just disconnect a vacuum line (it has to be vacuum) and see if its sucking air. If it is then you have vacuum and its not running boost. If its running boost you will hear it, does it sound like it spooling??
edit: i just watched the video, i thought you were talking about hitting boost at idle, like hitting boost while it just sits there at 650rpm. Thats what happens when you skim over the post lol. Hitting boost is completle normal when you free-rev like i explained above, the amount of boost your hitting seems abit high, and it seemed like it was a bit slow, my bet is timing...
Edited by R34GTFOUR
  • 1 month later...
Mine only makes 5psi or so on the 2nd or 3rd hard rev. Never on the first rev, thats a RB30det with a standard size turbo.
I got every thing back togetter.. but still having the boost issue.
But today was checking the TPS signal to make sure thats right.. And its not.
It reads 6.XX when closed, and like 9.XX when open.
I have a serious TPS issue...
I am still trying to work this issue out.
I ordered a Nissan Consult, and it should be here later this week.
Which should allow me to see what the TPS signal is.
If i cant fix eather problem, they will just wait till i get my standalone then.
I think if the TPS is reading that high.. that the car is sending a massive amount of fuel
Which would explain alot of stuff, like the really bad hesitation,
and the black when ever i rev it up a decent amount
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
    • Greg speaks wisdom. These dirty old Datsuns are only value when they are cheap. When they are not cheap, there is no value. Sounds contradictory, but it's true. We are now 20 years past the hey day of modifying cheap 90s JDM cars for small amounts of money. This is a different world. If you are rich and can afford not to care about what is effectively wasting money on an old Datto shitter, then I have no reason to argue against it. But if you are wanting to experience what we all experienced back in 2005 (and I bought my car last century!) then there is no way to do it.
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
