Hi all,
I was poking around in the boot of my 33 the other day changing one of my reversing globes, and noticed (not for the first time, but never bothered to investigate before :)) this motor mounted beside where the jack is stored. It looked all factory, and you can see it is supposted to pull a cable.
I did a bit of searching and saw a suggesstion somewhere that it could be some sort of exhaust valve actuator... so i got my dad to give my car some revs while i watched it... nothing... anyway i got him to watch it while i gave it some SERIOUS revs... and he exclaimed that it moved... sure enough i got him to rev it HARD... i.e. 6500ish RPM, and yeah it does move somewhere around the 4000RPM mark i think.
There is no cable attached to the motor, and obviously no exhaust valve or whatever hooked up to it, but i'm wondering whether it would be worth hooking up. My exhaust was FREAKING LOUD... then i got EPA'd for noise pollution, now it's just LOUD (i.e. bang on 90dB but it looks crappy with a single 2.5" piece of black pipe where there once were two massive 3.5" stainless cannons :)). I would like put the rear half of the 3" exhaust system back on (they cut the old one at the same place where they put the flange for the two-piece 2.5" system), and wondered if i could put some sort of exhaust valve (i.e. APEXi ECV or similar) in between and connect the cable up to this motor... that way under say 4000 RPM it would be nice and quiet.... possibly even having a bit more backpressure for the down-low torque that it misses with a larger exhaust (we're talking NA here...), but then if I'm really giving it some stick it would be open enough to allow more top-end power where i really dont care about noise... lol if i get EPA'd again i'd just disconnect the cable to the exhaust valve motor :). The best of both worlds???
it would be something like (excuse the crappy ASCII art):
                                     [exhaust motor thing]
_________                                     !
|         |                                    !          /=====[3.5" Cannon]=(
| RB25DE  |====[CAT]=====[RESONATOR]======={[VALVE]}=====(  2.5"
|_________|          2.5"             2.5"            3"  \=====[3.5" Cannon]=(
                                                           2.5"
Is this motor standard on all 33's? was there a factory option for a variable exhaust? I have done a lot of searching and found a fair bit on them for the 34's, but not much mention for 33's. Can anyone see a problem with my idea?
  • 1 year later...
are you sure that its not the motor for your aerial?
Absolutely. Why would the aerial be going up and down depending on the engine RPM?
After a fair bit of searching, it would appear that some models came out with a kind of exhaust 'flap' that opened and closed to increase backpressure down low and provide maximum flow high up in the rev range. I've actually got an APEXi ECV valve fitted in the exhaust, but no cable hooking it up to the motor yet (lol been there for months now though!), so it just stays wide open (VERY LOUD).
Gonna be turbo-ing 'er up very shortly (got everything to do it, just gotta find some time!), so I'm fairly sure I'll want maximum flow all the time anyway.
Just a suggestion. I also have a flap in my raer muffler. but i put it there. I have a Varex muffler on my gts-t. it is a very nice piece of work. with the valve closed it is super quiet, then with it open it is loud, but not to loud to get attention from the police.
yea my old R33 with the stock exhaust, I noticed that when looking down the rear twin tips, one was open and one was shut.
The other one opens when you really give it the gas.
Doesn't serve any purpose now though if you replace the exhaust as there's no flap there to control anymore.
All it does is close one pipe off at low revs and open it at higher revs on the stock muffler. It is a vacuum valve. If you have replaced the exhaust, then this will do nothing for you as your valve is not longer there :woot:
  • 11 years later...
I’m currently paying off a 33 and had a look the other day and it’s got the motor and standard real muffler that’s got a valve inside was trying to figure out if it was off a switch or not but if it opens at a certain rpm I would say it would open up to release pressure or something
42 minutes ago, niZmO_Man said:
Huh? Since when did Nissan bother to have variable mufflers in the 90's?
They just DID mate, suggest you direct that inquiry to Nissan, although who gives a f#ck now.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
