I use a 6 point Sparco bought from R & R speedsport. I always try and buy as much from them as they are nice helpfull people and not the Revolution rip-offs.
Neil.
Does R & R have have a website etc? I prefer not to buy from rip off places either and support the good retailers.
willans 3inch 4pt looks the go, cheers BB
https://www.sau.com.au/forums/topic/163567-best-harness/#findComment-3035881
There's a guy on ebay doing Autotechnica Monza 3" 6-point FIA harnesses for $170, dated 'til end of 2011. I bought the updated model (same thing, as far as I can tell, just a newer homologation) and it's great. Quality seems spot-on. Ok to be used as a 4-point, as far as I know . . . . ?
https://www.sau.com.au/forums/topic/163567-best-harness/#findComment-3035902
club is what you want. the silverstone is for open wheels and is NOT suitable for use in a sedan. the supersport is more suited to road use as it has a normal type buckle instead of the cam-lock quick release the club has.
not sure if race and rally have a website. if you are in sydney just go and check them out. they are in greenacre.
https://www.sau.com.au/forums/topic/163567-best-harness/#findComment-3036100
Being in the middle of the tarmac rally season Benson Motorsports have 3" FIA ones for $250 delivered and dated for 5 years.
Thanks for the heads up mate, though because i dont mind wasting money i think ill go the willans.
Im tempted to go with the supersport with the normal seat belt but then again maybe it wont perform as well as the club.
I think the club is the go, cheers fellas
https://www.sau.com.au/forums/topic/163567-best-harness/#findComment-3036172
Generally the more your spend the softer the belts and light the buckles... so its no bad thing to fork out extra!
https://www.sau.com.au/forums/topic/163567-best-harness/#findComment-3036295
super sport is ok if you want to use it on the street too, as the buckle is approved for road use. but personally I don't use my harness on the street anyway so i use one with a quick release cam-lock.
https://www.sau.com.au/forums/topic/163567-best-harness/#findComment-3036304
Hmm thats a tough choice, i know i wouldnt mind using it on the road
I did it for 5 days after Phillip island last week - It's RUBBISH! If you've got the shoulder straps done up anywhere near tight, then You can't head-check over your shoulder. NOT COOL ! ! Plus, it's just a pain, to unclip the harness, and have to loosen off the lap-belt, and re-tighten it every time you get in the car.
https://www.sau.com.au/forums/topic/163567-best-harness/#findComment-3036436
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
