Hey guys, for early r32 rb20det
Ive replaced coolant temp sensor 2 times, and replaced plug once, i can not find any problem with loom yet ECU still is reading Error 13 (Coolant Temp Sensor) - i know this is ECU pin 28 - what should this read at operating temp, and is there a way to bypass it or trick it into think all is well, as car is running rich as a mofo permanently and is basically undriveable
Edited by 040jqm
https://www.sau.com.au/forums/topic/163585-coolant-temp-sensor-drama/
something simple you may allready know but there is two temp sensors on the engine one for the cluster and one for the ecu the one with the single spade/wire on it is for the cluster and the two pin one is for the ecu.
is the sensor you replaced the two pin one or the single pin one?
cant work out where to find that wire in the loom, as it is all taped and covered in conduit....
it says 1v at 80deg, 3v at 20deg, so can i technically just bridge a wire from pin 27 which is AFM related and should only read from 1-1.5v
just try between the temp sensor and the ecu connector, no need to dig through the loom.
ok checked the voltage at the coolant temp sensor and ecu and they were both the same!!!
They should be
i have reset the ecu, and the code disappears, but comes back a few starts later!!!
According to the good book, error 13 is "Break or short circuit in engine temperature sensor signal system"
I'm guessing you have a break somewhere in the wire, but it only breaks the circuit under some strange orientation condition. I would guess it will be close to the plug onto the sensor. Try wiggling the wire while measuring ohms between the plug and the ECU end.
    • They are, a good friend of mine bought one to replace his blow factory turbo, running a Toshi Tune reflash. Just use their supplied water/oil lines and you're good to go. At the time, they were like $900 delivered.
    • This is an option for 100% bolt on, the GCG high flow -  https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html Also, I'm pretty sure hypergear does a high flow that is 100% bolt on, it just doesn't make as much power as their bigger high flows.  Even if you get a hypergear turbo that requires you to chance the intake piping, it is a really simple modification. It can be as simple as a piece of silicon hose and you pop a filter on the end. It doesn't have to be some crazy pie cut titanium work of art intake pipe.  If you have the ability to swap the turbo yourself, you would be able to sort the intake piping out.
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
