  • Replies 58
HKS Super Dragger Ex
HKS Dump Pipe
mesh removed from A/F meter (stock r33)
Apexi Air filter /partitioned off
Greddy 28c tube and fin front mount intercooler
Heat wrapped turbo to cat*
*cat in pipe
heat wrapped intake pipe
Power FC
HKS solid twin plate clutch
Cut out front bar
Oil air seperator
Bosch Motorsport fuel pump
Motul 5w40 oil
Nulon G70 with auto trans fluid in the gear box
1bar to 1.10bar boost
HKS EVC4
Pureone oil filter
Stupidly huge fuel filter
BPES7??? plugs 0.7mm
BP ultimate 98 Fuel 1bar- with octane booster for 1.1bar,also another 2degrees added with octane booster.
I`ll modify this post if I can think of any more
next time you want a tune up a freind has datalogit for r33 gtst... he made 280rwhp with stock turbos at 14psi....
i can arrange my tuner to tune it for you with his software in brisbane at a good price....
cheers...mark
  • 2 months later...
man took me ages to find this thread again. im sure everyones thats in the powerfc from the group buy will be looking for this thread also.
just a question.
would the fuel map work on any car with similar mods? if boosted or not boosted.
can anyone post anymore rb25det maps and list your mods.
thanks..........
My car had stock inkectors and fuel pressure, so the map would run your car. I have to stress that at high boost it detonated quite badly without 98 octane fuel. Every car is different ! But it may get you into the ball park before the final tune saving some time and therefore dollars. My base timing may have been retarded making the advance on the map look huge....there are soo many variables even on similar engines.
I would like to see the GTR map too.
I will be getting my car tuned at Gavin Woods in feb with following mods, so hopefully i will be able to post maps then:
GTR 33
Tomei 260/260 poncams, GT-SS Turbos, Z32 AFMs, HKS Cam Gears, TomeiFuel pump, TrustI/C,700cc SARD inj, 3inch exhuast, blitz id3 BC
  • 2 months later...
here, I hope Boostd doesn't mind, but I have got the Excell Spreadsheet here for download as a zip
http://members.iinet.net.au/~sennan/fcmap.zip
(right click, save target as)
ha just having a look at the fuel map ,seems a did messy to me
we spent a lot more time cleaning up off the normal power run path and trying to keep smooth transistion between different sectors
only in my opinion tho
  • 1 year later...
what tune are u after? i have a few
hi there..
i need a tune for my power fc i use T04Z turbine, greddy inlet plenum, 1000cc injectors.
thanks.. really appreciate it if u could email me on [email protected] for the charts. thanks.
once again thanks.
hi there..
once again thanks.
so goto a tuner and get a real tune then
hard to get a tuner here mate in my country. have to wait few months.. thanks.. can u email me just a light tune mate maps.. i think the ignition maps are too advanced.. thanks.. if u could email me on [email protected]. the tuner will come june 2007. and thats a lone way to go.. i really appreciate if u could send me one.
thanks.
im not sure what you are asking?
if the timing is too advance, back out timing using the temporary IGN adjust or edit it on the maps. this is covered in the PFC Faq in my signature.
there is no need to load someone else's maps, in fact its probably a bad idea
  • 1 month later...
cheers...mark
Any chance of getting yours friends contact details as I'm fitting a PFC and FC boost controller and need a good tuner thanks in advance :D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
