Nissan Cefiro For Sale *adelaide*
means13
 Share
Car
1989 Nissan Cefiro RB20det 5speed
ODO - 121XXX kays
[MODS]
boot lid and bonnet painted metallic Black
17"x8 speedy mesh style rims painted metallic black
aftermarket rearbar
aftermarket sideskirts
Speedlab Tune about 3weeks ago makes 142rwkw
3" jap exhaust from turbo back
Cusco Front coilvers with camber tops (front left is knocking)
HKS rear coilovers
pioneer CD player
FMIC
bigger fuelpump
pioneer 6" speakers in rear
Alpine 6" speakers in front doors
series 2 front bar
may have forgotten some things.
LOCATION
Adelaide- with a few months rego
CONTACT DETAILS
Sam
Ph# - 0411684008 - If i dont pick up msg me :yes:
Email - [email protected]
or you can PM me :P
[Other details]
car is silver aside from the bootlid and bonnet ;)
paint isnt the best but is far from the worst
runs fine, never been defected, never been pulled over
theres a rip in the drivers seat, (bolter arm part) very common
front left hand guard has a few dints
PICS
Cefiro Pictures
Edited by means13
ive had it for a while now, just only in the last 3 or so months got it regod in SA and started doing bits and bobs to it..
but ill still have a pimper car to cruize around in.. got myself a 32 4door :w00t: ready for a fresh coat of paint..
so the quicker this sells the quicker i get to paint my 32.. so BUY BUY BUY PLZ PLZPLZ
  • 4 weeks later...
  • 4 weeks later...
 Share
    • That is a dead f**king short of B+ to ground. Scary.
    • 10-15 years ago, the answer would always be buy a good import motor and so many machine shops make.a hash of an engine rebuild, or they think they are some sort of RB magicians and want 40k.      Now as others have stated, you are buying a VERY old used motor. So rebuild is the correct answer.  Just finding a machine shop that will both do a good job and charge you a regular price is now your challenge.
    • SOLVED   simple solution. After wrecking by brain, i ended up jist giggling everything i could. At one point last week I noticed that the left side signals shut off for a split second. I wasn't sure what triggered it. I spent time cleaning up wiring, re-wrapping and adding DT connectors to my IC7 stuff. I bought a new hazard and stalk hoping that would work. The stalk did fix some function issue but not the steady on. Hazard didn't fix it. I started just tracing everything. Once I got to the engine bay I notice my engine harness was droopy. I started moving it and the signals flickered. Come to find out that the starter + turned off sigmals when it grounded out on a bolt I have a Wiring Specialties pro harness so I'm not sure if this is specific to it. So it should work proper once I hook everything up   20240511_190033.mp4
    • Both of those things are on my to do but not quite in a position to do that just yet until I can at least get it running back to stock. Going to work on getting the exhaust manifold gasket and studs replaced first, an obvious need it now. Then I'll try out the new maf and see hownthat does. After that I'm thinking cas if I'm still having the same issues. Still need to run the fuel out and refuel I'll change the fuel filter tomorrow along with cleaning the iacv with carb cleaner. If all else fails I'm going to get a serial port and see if I can get some sort of data on what the ecu is seeing when the issue is happening but really hoping one of the methods above work out first. After I get a good base I'm going link but have to save for that so it'll be a while for that based on my tuners suggestions. Definitely need the exhaust leak fixed first though car has always fallen flat after about 4-4500 rpm since I've had it and suspecting that's the issue. Then I can move forward with the rest.
