12.45, I'm over it. Tool time....and tuning needed.
Managed to burn out mates stock clutch in his ca18det 180sx!!
Got a 1.9 60' and 14.6, 3rd gear slipping because clutch was fried.
I'll help him change it, I'm not that mean.
Anyway, a few other skylines out tonight at the creek, and no problems for most.
One r32GTR ran a 10.9, and sounded mad.
A stock black r34GT-t manual ran in the 15's, and a handfull of r33's and silvia's.
At least the weather held up.
Yup very packed last nite due to a few reasons.... a falcon dropped about 398m's of fluid, it was bike nite (about 60 bikes, omg i'd rather watch paint dry) and last Wed + Fri were rained out so that plus school holidays every p-plater in his mirage wanted to run 17's.
Blitz didn't show (smart move).
A few quick VL's in the 9's (Rigoli) and also an r32 gtr did a 10.9 with atleast 1/2 sec more in it (bat launch - looked like it had crappy 17" street tyres). A few other low 11sec gtr's too.
Omg I hope those stunt bikes aren't going to be a regular thing, their is only so many times u can watch a guy do the same trick on a motorbike (did I mention I hate motorbikes?).
Does that mean they bought back FRIDAY NIGHT drags @ WSID?? That puts a smile to my face :( :( :P
i bloody hope they open friday nights again.....it was too packed last night.....i turned up on time and got 2 runs.....when i was getting on average 10 runs a night back in november....
stuffed both runs so it was a complete waste of time...
what r u luanching at?
coz i would have expected better then that from ur car
i was getting 12.50 with 240wkw with crappy falkens on the car
brett
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
