Hi Guys jus recently purchased my r33 gts-t, great car now i need all ur opinions on what should i do to the car such as servicing and what to do to make the car look clean and is it alrite to go to those car washers and put a degreaser wash in the engine bay or not and another thing is
Modifications wat to do first nefin from sound system to gauges to controlers to engine mods small stuff first no budget jus want i deas to begin with but small stuff to start off with and want more power yerrrr......... Thanx Guys
https://www.sau.com.au/forums/topic/163925-what-should-i-do/
minimum usage degreaser on your engine bay for starters, wash the engine with soap and keep it running so nothin earths out. then polish all the paint inside your engune bay..thats what i did.And regular polishes every 2-3 months.
as far as mods go purchase a full 3inch turbo back exhaust, get some nice rims and lower your car. then if you want to boost it up follow the sticky trhread in forced induction performance. :laugh:
good luck with your new car mate :P
full turbo back exhaust should be first on the list. then pod filter, then up the boost to about 9psi, and get an intercooler upgrade (either r34 side mount cooler, or front mount cooler).
after that you can lower it and make it look pretty if thats what you like.
i would do the pod filter first since its the cheapest, and u can get one of those drift ones and they make a cool whistling sound....and get an oil pressure gauge, boost gauge, water temp AND FOR THE LOVE OF GOD will people please upgrade your brakes... ffs anyone would thing those weeny little brakes will actually stop you.
Change, all oils, brake and clutch fluid, belts, and if your timing belt hasnt been replaced then hell might aswell chuck that one in, check your water pump while you are at it, change fuel filters, intank and inline, thats all i can think of right now.
not sure what you already got so the following are the fundamental mods that most people get...
1. Pod air filter... recommend Blitz 4000 superblow.
2. Full cat-back exhaust - 3.5 inch HKS perhaps?.
3. Boost Controller - recommend eletronic one.
4. Front Mounted intercooler - HKS or Blitz brand or Hybrid etc.
5. Change driving lights - HID perhaps?
6. Get a nice DVD/CD/MP3 Deck/Screen combo - Pioneer perhaps?
7. Get some subs, tweeters / speakers?
8. Blow-Off Valve for good turbo airflow + sound? GFB or HKS?
9. Nice set of 18 inch or over mags... can't spare the cash here... the mags do justice to your ride.
10. And finally..... a nice bodykit... this is option and totally personally.
That's all I can think of that are 'standard' mods - well, those are my mods anyways...
Good luck mate...
SKY
degreaser in the bay will be fine just dont put it on the paint... someone mentioned polishing the bay every couple on months thats extreme for a road car but each to there own. mods wise as said before id be going the full exhaust/high flow cat, sports panel filter or pod, there was a right up on a budget the r34 ic is a good upgrade for the extra bit of flow and yeh boost controller and wind the boost up....
i meant polish the actual car every 2-3 months lol engine bay once or twice a year to keep it fresh
the r33 gts-t has 2 piston front brakes. in mine there would've been no point upgrading as they locked up easy enough as it was. so bigger brakes would've meant more lock ups. and as it is they will out brake a lot of cars out there, so there is more chance of having some stooge in a commodore running up your arse if you have to stop in a hurry.
depends on the degreaser. i just get a few cans of that export stuff for about $1 each. does the job and doesn't damage the paint. if it does damage the paint then your car has had a respray and it was a very dodgy job.
i just spray it on everything, then get a new toilet brush and scrub over everything, then hose away. then run the engine for a while to dry everything out.
Kralster.... you dude are stupid
Yes so does an r32, upgrading your brakes actually assists with the removal of brake fade. which is what you dont want when coming up to a corner, thats like saying hell ill upgrade my car to make 250-300rwhp but f**k the brakes, they dont need to be upgraded. The car was manufactured with a limit to hp in mind, when you start exceeding that your braking performance cant keep up. and if you have to stop in a hurry A) id rather be able to stop in a hurry and not smash the front of the vehicle if possible, and if the stooge behind you doesnt brake hard enough he was probably following too close so it wont be your fault.
By an upgrade to the braking system... good pads, rotors slotted or something, a good brake fluid (something that can handle some heat), and if your really up for it (or the car needs it) some new brake lines, with a preference to braided. There are options for going further than that but you shouldnt need them for a while.
But to get some fun out of the car safely, do the above with your brakes. Do the suspension while your at it. Get the engine breathing a bit better, so exaust, split dump pipe, a good filter with cai. Maybe some more boost. And if you can get one a pfc would be a good upgrade, and upgrade the intercooler, as mentioned an R34 standard sidemount would be fine. Then the car will go a bit better, and handel MUCH better. All the while being safer.
It looks like he'll be doing some fairly basic upgrades as far as power is concerned, I think you'll find the stock brakes are more than adequate.
It is a good idea to fit some quality pads and change the fluid but apart from that the stock 33 gtst brakes a very good.
For street driving there is really no point, now if you were going to be going to the track then yes, you might start to experience brake fade but for every day driving and the occasional emergency braking situation, there is no point in upgrading.
well its nothing special but here are the pics of my 4 door r34 with basic mods including stereo, rims, and lowered springs.... its auto non turbo but it does the job for the moment until i get the turbo model.... hopefully
http://www.skylinesaustralia.com/forums/in...howtopic=163910
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
