  • Replies 40
Didn't another skyline crash there last year I remember reading on here?? Thing is even if you change lanes a bit fast and flick it bick a bit hard you can get a bit of a parallex skid happening.
Worst thing about skids is you don't actually know its skating until you feel it kick back, by which time it could be too late :) :)
i lost my 31 at 140kmh going over the top of a hill in taradale,would have done 12 360's,managed to keep it off the dirt walls either side,only thing that saved us was the abs i reckon,come inches away from each wall,but i corrected her nicely.last time i go silly in the wet at high speeds,low speeds well that a different story nothing like lock to lock in a liner.
ps: dont buy hankook tyres they suck all round
Originally posted by R34GTT-R
maximum braking without locking up all four,must of helped coz im still here writing this sh!t,without abs i woulda had the 4 locked up and at 140kmh i would slid till something stopped me (wall or tree)
correct me if im wrong someone(with proof), but i dont think the fact that u had abs would have made a difference if you did 12 360's. how did u know you did 12, did you count them as you went round?
Originally posted by Ender
Anyone who loses it on the freeway fullstop is a dickhead...it dosen't get much easier than driving up a five lane divided bitumen rd does it??
fullstop? so even if he was cut off and had to swerve to miss, or if someone braked heavily in front of them and swerving to miss was the only option?
are they still dickheads?
Hmmm.. isn't one of hte first things they teach you when driving is to always drive to allow for others mistakes?? If you are driving too close... or sitting parallel next to another car doing exactly the same speed then well ..
Anyway, none of us were there, so of course its impossible to pass judgement on how the driver was driving, or why it did occur.
thats what i mean...but when its raining its a lot harder to keep an eye on everything that goes on...if its raining really heavy its normally dark..ie lights are needed...not everyone turns on their lights because its not night time...i guess my point is, it might not be the drivers fault that was involved in the accident
Had a full car load so that was the overall guesstimate averaged.
point of my story is its stupid to go fanging ur car in the wet at high speeds.i was lucky unlike that other poor prick on the freeway.
yep, I believe you can fairly easily anticipate and allow for other peoples mistakes. I guess if you had a fairly catastophic blowout or mechanical failure you may be excused...so maybe not fullstop...but almost. In my job I have the opportunity of reviewing many car accidents and I would say 99.99999% of them are due to preventable driver error. Mate people mostly do a really stupid thing or aren't thinking....most accidents shouldn't be called accidents...they should be called stupids.
Point taken though...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
