I'm almost ready to buy a stagea, i'd say in the next month or so definatley.
i dont think i have enough money for compliance at the moment tho. but can afford the car and all the costs to get it here.
can i still import the car, get it home keep it there untill i can afford compliance??
and anyone got a rough guestimate on compliance cost for a 1999-2000 stagea?
Cheers
:dry:
https://www.sau.com.au/forums/topic/164030-importing-question-compliance-etc/
yeah i thought so.. 1% rise is only really 50 or so bucks so waiting for the dollar to move isnt really that cost effective
i might post in the stagea forum. about cost of compliance. i budgeted around 4-5k....
Edited by Angus Smart
Although there's a time limit on compliance, most RAWS require you to bring the vehicle once it's left the docks because if the car isn't being complied, that's one less plate available to them.
Try the Imports101 website. It has a good cost calculator that actually includes all the necessary items for your state. (Whatever that is).
You may be surprised by how much difference to the end result the change in the value of the yen makes when it goes from, say 96 to 97 to the dollar. It works out to be quite a bit more than $50....
Buy one locally in aust now i reckon, prices have plumitted. Plus unlike the experiences i had, you can see and drive the car, take it to a mechanic and all other things before you buy it :happy:
Otherwise you might get the "one-in-a-million" car with a f**ked engine like i did :dry:
To be honest the calculator is actually pretty good. But at the end of the day it is only as good as the accuracy of the FOB price you put into it.
Unlike alot of calculators the Imports101 one lists all of the stuff you will end up spending money on. It doesn't neglect stuff & assume you live in Queensland (Which is the cheapest state to get an import into)
yeah i understand the whole try before you buy here. but there isnt too many leather stageas out there for under 18k and thats what i want!
yeah looking at the calculator it does seem good! minus the 600ish for their fees :P
You need a permit from FORS to import it, it would be a prohibited import without one. they only cost fifty bucks, but they can only be issued to a RAWS for post '88 cars- most will want a deposit as well, usually around a grand. Stageas are around $2500 + tyres to comply, depending on the RAWS and how much extra work hasto be done, like remove/refit mods etc.
Bikkies you might want to update your info before you post. FORS hasn't been around for years and aren't responsible for issuance of the import approval.
DOTARS then- force of habit from having to deal with the sods for years- went through all the rigamarole to get low volume certification on SWB V8 Land Rovers, took four years and about 100K then the arse fell out of the dollar. Not my favourite organisation.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
