  • Replies 114
It's just a figure of speech...but will change it as cant keep being petty about stuff
The girls and guys are going to be in the SAU shirts
Are you sure you dont want to help out Mona, Would be great to have you as a helper??:)
Any helper that doesnt have a SAU shirt please check Merchandise thread and get one....which ever style you prefer it doesnt matter we just need to stand out on the day
http://www.skylinesaustralia.com/forums/in...howtopic=156571
Thanks :P
Thanks :P
Just a comment on the shirts as well there is a limited size on the girls polos so get in quick :)
speaking of "promo shirts"
I got one at the dyno day - and bloody good!
and support ya club peoples - they are cheaper if you are a member dont forget!
And why wont you be there the whole day Mona?
support I say support! :D:blink:
support I say support! :D:)
No need to panic - the shirts have been selling really well, and a new order is being put through tomorrow, with more in Womens' sizes, a new style of polo, and a new style of cap! Check out the first post of the thread for more details - link is in my signature! :):D
And Mona, what's the story? No running away allowed, okay? :P
LOL!!!
nah.. just not a morning person, so will hardly make the 8am meetup, or whenver it is :( and if i did i'll probably be asleep by midday! i'm getting old! lol!!! will try and be there to support the club for the rest of the day though :)
And nick!!! please tell your sister I wanted to chat to her again, but she was busy when i headed back her way.. and then we left soon after :(
im interested andrew if you havent already got engouh judges
Sweet will keep you posted Drift King Chubs has the info and we are needing to cut it down so we can get through all the cars by then end of the day.
Will speak to you soon bud.
Chub :P that is all i can say you are da man
Chub :O that is all i can say you are da man
ok cool
well... theres a rumour been going around that its going to be huggeeee
Alright peeps....
We are having a meeting for SNS and I would very much like it if you could all come this Friday so we can organise what we will be doing on the day :P
This pub does serve good food so you can have dinner there and most of us will be :P
Date:Friday 1st June
Destination:
West Ryde hotel
Victoria Rd
West Ryde
Time: 7:30pm
Hope you can make it....
Jess
Alright peeps....
We are having a meeting for SNS and I would very much like it if you could all come this Friday so we can organise what we will be doing on the day :thumbsup:
This pub does serve good food so you can have dinner there and most of us will be :D
Destination:
West Ryde hotel
Victoria Rd
West Ryde
Time: 7:30pm
Jess
See ya there! sesh I might as well crash there the next couple of nights so I don't have to leave. haha!
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
