Hey guys
For those of you who have been following, I have gotten a slide highflow turbo charger. The turbo was installed properly, and there are no problems. The purpose for this post, is:
1. If you are running a slide turbo and have had the same observations, please say so.
2. If you're a turbo guru, or have researched this area, please comment why this is the case.
Most of you have driven an rb with a stock turbo, stock bov and pod filter. The things that you'll immediately notice are:
1. Massive induction noise when pressing the gas. This sounds like a sucking noise. It's sick, I like it :)
2. When you release the gas, you hear pssscccht. Even though the bov is plumback, you hear it throught the pod because the noise isn't muffled like in an airbox.
After installing the slide turbo and running 11 psi
1. induction noise isn't as loud. I put this down to the fact that the exhaust has also gotten louder, so I can't hear it as much.
2. I don't hear pssscccht unless i'm up at about 4.5-5k rpm before I release. If I release before then, I hear flutter.
I thought that I mgiht have left cloth in the intake piping, or that the bov was seized, so I took it off, checked it, the vac line wasn't split etc. It was as if, with the stock turbo, if someone had tightened the bov spring.
At low rpm, even if i release my foot when the boost is like 3-4psi or something, it still flutters. I do not believe that the bov can't handle the flow of air, because i've run a stock turbo at 20 psi before for testing purposes, and it didn't even flutter when releasing, just made a massive woosh. surely the slide turbo at 3-4 psi does'nt flow more than the stock turbo at 20psi.
This thread is not for flaming slide turbos, but rather, to gain an understanding of whether it is my particular setup that's doing as I observe, or whether it is the turbo that's different. Just like how nic's thread is the definitive thread about slide turbos on rb20s, I'm hoping that this thread can turn into a FAQ for the other aspects of the slide turbos. Hopefully it will save a bit of time for slide as well, because i'm sure he gets asked this stuff a lot.
Some questions that you guys mgiht want to answer (not all are relevant to everyone):
1. if you have a slide turbo, is this your exact observation? if not, please comment on how it's different
2. if you have experience with another type of highflow, is the induction noise louder or softer than the stock turbo? does it also flutter when you let go at low rpm, and psscccht at higher rpm
3. For you turbo gurus, why is it that the slide highflow flutters when releasing at low rpm, but not at higher rpm?
Edited by MANWHORE
https://www.sau.com.au/forums/topic/164290-slide-turbo-induction-noise-flutter/
  • Replies 60
the sympton you have described is due to the bov not opening enough or incorrectly
as a result it surges back onto the compressor wheel and you get the air chop chop / flutter noise.
you could try adjusting the spring on the bov?
forget all the sounds etc, all that is irrelaevant at this stage.
pressuming u have a FMIC and boost controller, get your hands on a ECU (if u dont have one) and get it tuned, only then you will take advantage of the hiflows potential
stock turbo:
a compressor winds up to 3000rpm it has 7psi and 45cfm of air
hiflow:
as compressor winds up to 3000rpm it has 4psi and 25cfm or air
i think the stock bov spring is too tightand wont fire
you could try loosening the spring to make it fire with less air volume/pressure
it needs a certain level to be reached when the throttle body closes.
if the bov doesnt fire it will recirc back to the compressor and chop itself / collision
dont confuse the bov spring rate vs manifold boost pressure
it doesnt work like that, the bov fires when manifold pressure spikes through the roof
ie: when the throttle body closes, its probably more like 30psi+++ when the throttle body closes and the compresor is still flowing
a bigger turbo has completely different characteristics to the std one
exactly what he said, turbo doesnt spool as hard or as much air as a std one, its what you get when bigger turbos are fitted, if your just after noise you go back to the standard turbo but personly and most ppl prefer more power.
Paul
It is the stock bov. Not adjustible. It is definitely working. I tested the mecahnism, and the firmness is the same as when i had the stock turbo on. It's not siezed etc.
Edit: I just read your later post. I disagree in a sense. Because, going by that theory, ok, if the highflow has only 4 psi at 3k rpm, when the stocko would have had 7, that means that if I released my foot on the stocko at 2k rpm when it had 4 psi, then it should flutter?
You still have the stock turbo. Can you test it? I never had flutter ever on the stock turbo, whetehr releasing at 1 psi, or 20 psi
Edited by MANWHORE
silver - No offence to you personally, but i'm not some noob who doesn't know that I need to tune it to take advantage of the potential. If you notice, I made no mention of the response, or power. This is not the topic we're discussing here. We're talking specifically about the theory behind
In answer to your question though, it will be getting a z32, increasing boost to 19 psi, injectors and a tune.
That doesn't answer why the bov noise is like this, and even after doing all that, it's still going to do the same thing, as I won't be changing bov.
Edited by MANWHORE
i believe the bov is ok and hasnt failed. i believe the stock turbo didnt flutter. i believe what you are saying
im just looking at it logically and dealing with the facts that we have.
maybe its just a case the stocker flowed more air down low (very likely) and it was enough to fire the bov in all situatons.
ie: it was designed around the oem stock turbo flow so its mapped around that level of airflow and pressure.
now that the compressor and exhaust side is different it could be unmatched. i am unsure on the fix sorry
Waz, i'll just answer this question quickly, so as not to divert the aim of this thread (so other people don't divulge on this tangent):
It is very very laggy. On the stock ecu on 11 psi, any gains are not noticeable due to r+r (i.e. power output is probably similar).
It wasn't a direct bolt on, had to bend the lines, and rotate the housings.
I'm not after the noise of the stock turbo - otherwise i'd just run the stock turbo. I actually like the flutter, it's sik but that's besides the point.
I'm trying to understand why it's happening, and why the bov isn't opening yet.
spend 900 on a highflow or 2k+ on a hks direct fit unit...
do you know what your talking about? my highflow that i baught of aaron is a straight fit, no rotating housings nothing, but because i want to, im getting braided lines made up so i dont need to drill anything.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
