and in a straight line (with good mods), Autos will beat Manuals...
if the manual has the same mods the manual will still win, unless you are talking 10 second cars, or the manual driver keeps missing gears. manaul gearboxes are lighter, you can change faster and at the rpm you want it to change at. if you are talking BIG power cars then an auto can be the way to go.
the best way to launch an auto is, as people have said, left foot on brake, right foot on gas, bring revs up till the car is about to start wheelspinning. if you are coordinated enough you can use the hand brake too. this will add more braking power onto the rear wheels.
using the handbrake is a good way to load up a manual car too. doesn't do the clutch much good though.
thanks guys. been meaning to ask this question but keep forgetting that i wanna know. is it possible to do a standstill burnout in an auto as well?
i skipped most of the replys so its poserbly all ready being said. but yes you can do a burnout in an auto and it is easer then a manual.
just bring the car to a stand still. step on the brake bring the revs up release the brake a smudge, (this locks up the front brakes) keep incressing revs and you should have the rear wheels burning. then just controll how much power you give it and how much brake you wont (to controll how fast the car moves)
This is being a little mean but i had these conversations with friends in i think Grade 4 when i was learning my 7 & 8's times tables.. but not up
to my 9's as yet.. they were a little hard at that time...
But anyway, straight out unless ur car is making 200rwkws and u have 3:9's or higher gears ratios in the diff auto sucks and manual is much more fun..
People who say auto is faster etc etc, can eat an overdue banana. Manual delivers power in a completely different way, more power goes
to the wheels with a manual gearbox as to an auto in ANY car..
As said earlier in this topic, autos are only quicker when cars are running 10 second passes and u need more traction, manuals are full of
wheelspin when ur popping the clutch and smashing through gears because of the way the power is being delivered to the wheels..
I had an auto Passage with 110rwkws and no matter how hard i stalled up the auto off the line a manual sigma would keep up untill atleast 40kms.. lol
Edited by Dean_HR31
Auto Trans rebuilds are too expensive, its LOTS cheaper to purchase a 2nd hand one as they are being sold for a couple of hundred bucks. I picked up a second hand one for 2 cartons of beer that I saw come off a car and the only reason it was changed was for a manual conversion. I will be slowly upgrading the trans to have a manual shift kit, hi-stall and new bands ect.... So that when mine goes bang, it will be easy to swap over. But for now I have a bigger trans cooler and I also service it every 10k, so I am not expecting it to break any time soon.
Chris
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
