Hi
I want project for 650 whp for my GTR34 V specII 2001 WITH OUT feul system !!
what is your opinions ? :P
please : but who is know with details !! injectors,,metal head with size??
intercooler size 2 ROW 3 ROW ,,
cam shaft (gear) lift & duration ...etc :O
and what about Apexi cam shaft 264 !!!!! lift I think 10.25 & from A better same camshaft with duration
AND lift OR DIFFERANCE ??? WHY :(
Thank you .
https://www.sau.com.au/forums/topic/164554-prject-650-whp/
  • Replies 84
ok...
i guess your 1st language isnt english...
are you tring to say you only want to run pump fuel? (fuel you get from ur normal petrol station).
and you want to run 2tanks? or are you asking you can run an intake fuel pump, and (or) an out of tank fuel pump? (maybe surge tank?)
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049707
in for page1
ok
I mean change feul pump high pressore ,, injectours,, regolator metal,, turbo intercoler but i want fuel pump
in tank 1 or 2 I can that it ? or not .
GTR MINE's i think don't fit feul system !!! 600 whp !!
my gtr34 fit it intake system greddy complete exhaust . twin plate clutch nismo G MAX BLWOF VALVE HKS
x 2 .... twin exhaust manifold only ... :P
and my idia canceled up pipe for the turbo !!
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049700
ok...
no no this is parts i fit it in my gtr only ...
but I mean i can fit it feul pump in gas tank !!! 1 OR 2 I don't like fit fuel pump out tank !
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049723
can put an 044 intank with a bit of playing around.....
He appeared it is possible that is legal from then she dug you or from your experiment for the arrival to 650 WHP ??
WITH DETAILS !! please :P
and what is your opinion ( Apexi cam shaft ) 264 lift 10.25 ?
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049748
Join today and ask questions without gramma in them, im not sure what this is intended but have to ask do you speak fluent english? Maybe inted your questions properlly, Are you trying to say that you have a 34 gtr without a fuel system, or what is the intended purpose of asking the question, What question are you trying to refer too?
It has no fuel system?
You want to upgrade the fuel system to support 650 rwhp?
What mods do you need for that power?
Maybe start with the basics:
What has the car got in it first?
What turbos, standard or aftermarket?
Best to list the mods it already has in a list form, maybe include a picture this will help :P
Aswell as where abouts are you? Australia? Are you on school holidays
Before we can help you you need to help us
Thankyou
Adam
https://www.sau.com.au/forums/topic/164554-prject-650-whp/#findComment-3049766
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
