You take the unit out, then unscrew the front of it. the blubs are set in a little clip which unscrews and you can take it out. Good luck finding new blubs to fit, mine has been blanked out for a while now because I haven't been able to find new ones.
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3050152
i believe there was someone doing a group buy of different colour led's on the GB thread so maybe do a search and see if he has them yet? they were gonna be in white (std) blue amber and i think green? had a few pics of them installed in gtr dashes adn looked the goods, so might be worth sussing out?
cheers oxford
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3051152
Jump on the Yahoo auctions. There are quite a few kits on there for them. Most of them seem to be blue though, but if thats not a drama (wouldn't be for me) have a look.
http://page10.auctions.yahoo.co.jp/jp/auction/m39813386
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3051798
I got bulbs for mine from dick smith in brisbane city, can't remember the part number but they were tiny 12v bulbs. I just took the ones out of the car into the shop and compared them. They came with wires on them already which i stripped to bare wire to put in the unit. That was about a year ago and they have been perfect ever since. If you do go ahead, the stock bulbs have little blue sleeves over them which are very fragile, try not to damage them when you take them off so you can re-use them.
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3053314
cool!! why didnt i think about Dick smith!! BTW is it hard to take out the front panel of the climatic control?
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3053891
No Yudi, it's very easy...
Just use the guide for removing your head unit, and once you get the whole section which holds the stereo, guages and climate control panel out, it'll be easy from there.
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3059320
Ohh oK thanks Nick. That shouldnt be a problem since i change the headunit myself. THanks again. This Led light have been bugging me since i got the car almost 1yr now. Geez thats quick 1 year already. I dont think i will ever sell the car, it will be a ripper in abt 10yrs.
https://www.sau.com.au/forums/topic/164574-led-light/#findComment-3059386
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
