Hi everyone, I'm fitting a GTR bonnet to my R34 GT-X skyline, i have a pair of conversion hinges and top mole (nose) on order.
Can anyone tell me what needs to be done to the cars lock mechanism so that i can retain the catch on my new bonnet?
If you have done this your help will be greatly appreciated.
Thanks.
Well you could try buying the GTR latch from nissan. About $80 brand new.
Not sure if it would solve your problem , you might also need to the upright part the latch bolts onto as well.
Is that all it would cost, i assumed it would cost an arm and a leg, had been trying to find a GTR that was wrecking.
Thanks, will call them tomorrow.
Thanks.
You will need both GTR latch and latch support if you are using a genuine GTR bonnet.
what front bar you going to use?
I'm using the factory fitted front bar (as shown in first post) but you can also use the Nissan Aero front bar as you can buy a front mole for that bar aswell.
The ultimate front bar for this setup is the East Bear GTR version as it fits non GTR's without changing front gaurds. (shown below).
I was bidding on the same bonnet you bought, but with frieght to Brissy it became too much
Yeah, could'nt believe my luck when i won the auction, i was'nt actually looking for a GTR bonnet but as a new one would have cost three times that amount
retail it was a bargain especially as it was brand new and had never been fitted and pickup was only 20 mins away.
wow, i should have really looked into the price before i got mine modified...
where did you say divide by 3 before? i can't find it... and i have no idea what the average market price for a bonnet is...
Average price for a R34 GTR carbon bonnet approx $900-1200
This new one sold for less than $470 on ebay. Was old stock and shop wanted to get rid of it.
It was going to cost me approx $150 freight plus the chance of it getting damaged, so I did not bid too high on it
Plus I already have a genuine alloy 34GTR bonnet on my Stagea
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
