  • Replies 67
cool...thanks grant.
mate has a set of eurolines ..18*9 and 18*10 ..both with +35 offset...i'll try them for fit this weekend....oh and tyres are 235 at the rear too...really stretchhhhhed
wont fit in the rear it WILL hit the coilover, you need a 25mm spacer to clear them
the front will be kinda sunken
BUT if you put the 10 in the front you would be fine, but it woudl be stupid
Nice, Marc. Must come back to Canberra to have a sticky-beak...
Front 18x9 +30 Rays GT7, Proxe(?) 235x40x18
Rear 18x10 +32 Rays GT7, Maxxis 245x40x18 plus 3mm spacers.
Prior to WA road rego was tyres rear Proxes also, 265x35x18 but self destructed between Brisbane & WA. (bugger)
Ride height ~380mm all round. At this time.
cheers GW :ermm:
edit. plate removed.
Edited by 260tech
I thought the R33/R34/Stagea AWD system was like other AWD's - in the fact that you have to run the same size tyres front and rear?
Is this not the case?
I know you can get away with it for a while, but you'll end up burning out your drivetrain, correct?
Ref wheel diameters/profiles front to rear, I'm sure you are right however my GTIR equiped son tells me that my car is only 4wd when the rears break away & to date I have not achieved this. Too busy messing around with it plus tyres cost $$$$$$$$$$$$$. The 35's came with it of the boat so could well have been half shagged before it got into my hands. By the time I got it to WA they was chewed out on the inside edge. I will not be fitting that profile in the future unless it is all four.
Cheers GW :wub:
how much lower are you than stock?
nevermind.
i guess i really DID have that much camber lol
looks good man!
I would say about stock height. Any lower & it slurps up beer cans off the road.
Cheers GW :wub:
i pulled it becuase i hate 4wd
its still pulled now.....
im not in snow or slick surfaces, so i dont need 4wd.... its overrated around my area...plus i like drifting and big smokey burnouts
Why did you get a Stagea again?
i've had a galant vr4 engine with a gsr 4wd gearbox fit in a lancer before which in fwd mode.....mechanics had to weld something in the tranny to stop the rear from spinning....did you have to do the same when going rwd?
  • 2 months later...
in answer of nz_26t question on whats the bigest rims you can fit under a serries one stag (i answed it here as i belive we should keep this thread alive.) my friend has a serries one 96 model and has just recently fitted 20x7's not shure on the rest as i don't speak to him much any more.
don't happen to have any pix do you of the 20's on?
any problems putting them on with guard clearance & so forth?
sorry fuzzy as i said don't talk to him much and haven;t seen him in a while. all i do know is he got his serries one stock, fitted exsahust and got it lowred by reseting the factory springs only resulted in 30mm drop. wacked on 17's then upgraded to 20's after ruining a 17. no gaurd removal just bolted them on no spaces and i think it looks f#@ked the rims sit to far in and it looks like a monster truck it's that high off the ground. as i said though there only 7" wide if you are going to get some get them through a reputible dealer and get the write off set. lower it as far as possible then even get a body kit so it looks low and suits the rims
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
    • Yes it is ATF. I quote @Duncan "it takes a good synthentic auto trans fluid like Castrol Transmax Z" It's not a diff. It's a transfer case. Totally different thing. Yes, fluid will come out the sender hole. No you do not really need to drain it. Just pull the old, quickly poke the new, clean up and top up. But realistically, you should probably take the opportunity to change it anyway.
    • Hey all. I’m looking on replacing my speed sensor on my R33 GTR. Will the center differential need to be drained, and if so, the center diff uses ATF fluid D? I found information on the transmission, front diff and rear diff. Can’t find a for sure answer for the center diff. Any help will be greatly appreciated.
