hey guys
my amp just died on me. well not died exactly, more just stopped working.
it has power at the amp terminals, the amps fuse is in tact, the main pwr fuse is ok.
shit i checked every cable to it.
its a boss audio 1400. bout 6months old.
ideas?
https://www.sau.com.au/forums/topic/165088-amp-just-died/
its a boss... its dead...
they blow like a hungry hooker man... ive blown more boss amps then all others combined... no shit...
On the off chance its not f**ked, do the normal checks...
you say it has power already, it might be in protect, let it cool down...
you might have disabled the sub pre out on the head unit... maybe...
check RCAs and what not...
check your signal wire from the head unit... if that has fallen out, grounded or broken, it wont know to turn on...
if its under warranty, go get it replaced (they dont bother fixing it most times) otherwise, go buy a better amp... please...
https://www.sau.com.au/forums/topic/165088-amp-just-died/#findComment-3058371
did all the usual checks. all the rest of my system is pioneer, including the new subs i have.
how do you rate the pioneer amps?
might just get myself 1 of them.
over priced... you pay a good percentage for Pioneers name... its all money with amps, pick the amount of power you want, then the amount of money you have... then come back and ask again :P
its dead. replace it.
wise wise words :P
https://www.sau.com.au/forums/topic/165088-amp-just-died/#findComment-3058874
there are a lot of GOOD brands depending on what you want.
suggestions are:
DLS,Blaupunkt, ALPINE (PDX) for a start..
cheap crap will go boom boom for a short while then bang as you have found.
https://www.sau.com.au/forums/topic/165088-amp-just-died/#findComment-3058980
I honestly heard not a single good word about Boss subs.... My mate leant me one and said you can have it for $150.. but after reading everything about it im inclined to give it back to him.
Ive got a similar setup to you cheez, im looking at getting a sub+amp, just dont know what to get haha
https://www.sau.com.au/forums/topic/165088-amp-just-died/#findComment-3059072
got 350watt pioneer 6x9 rear speakers and 800watt 10" Pioneer Sub.
what sort of amp and power rating do you guys recommend?
dont quote the max power for starters...
as for brands... ask chris rogers... im just here for the help :P
https://www.sau.com.au/forums/topic/165088-amp-just-died/#findComment-3059245
Look at the RMS of the speakers and sub and go from there. Try look for two amps, one for the front/middle stage and one for the sub. But it depends on what sort of setup you're after.
I would also look at removing the 6x9s for just some filler, the sub should be producing all the necessary bass. That is of course, if your front stage (front of the car) is decent.
Me personally, I'm not a fan of buying based upon brand name. Don't go buy an amp or sub because it's cheap or bacause "Sony rox", research it and try listen to it in a car not on a board. Speak to the installers, see what they are running and recommend. Spending a few extra weeks and a few hundred more doesn't give you these situations where amps just die.
All lessons though, we are all here to help you through.
https://www.sau.com.au/forums/topic/165088-amp-just-died/#findComment-3060634
hey guys
just an update. problem solved.
ended up being the fuse holder on the power wire. the encase had cracked and some how was making contact with the metal on my car, thus causing a power surge and amp just refused to turn on.
replaced holder, all well in love and car audio. :P
https://www.sau.com.au/forums/topic/165088-amp-just-died/#findComment-3063417
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
