Ok guys... it's time for another big cruise this coming friday the 23rd of May.
Meeting will be @ the Lindfield car park which is behind the line of shops on the non-pacific highway side of Lindfield train station @ 9:30pm
Destonation is open for suggestions... maybe Palm Beach
We hope to see alot of new faces on this cruise so if you've never come out before then do so on Friday night :uh-huh:
MEETING SPOT MAP
Attendee's List
SW20-GT
Blitz
RANDY
Kinks
Morgs (maybe)
Carlo
slo200
RXB05S + friend
JiMbO
RedGTS-t (maybe)
MRK25T
T0nyGTSt
a5h (maybe)
Da_Man + friends
Merli (maybe)
Duncan
Lozza150 (maybe)
Endorean
https://www.sau.com.au/forums/topic/16527-cruise-this-friday-23052003-930pm/
  • Replies 91
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
