  • Replies 58
haha results posted........In first thread
Also I used united fuel Boost98..
Im stll shocked it made this power I wasnt expecting any more then 200rwkw..Im happy.
See yous at the SAU dyno day nsw's peoples..
Cheers
Liz & D
I GOT RESULTS BACK - I am suprised with the results and Matt done a great job....
234.9RWKW@11/12psi.( I dont know why it ran the higher psi as it has an rb20 acuator on it.
Only issue I had was with the spark plugs, it was blowing out the spark at this boost level, there copper and were gapped to 1.1 now Matt regapped them to 0.65.
He didnt mention anything about fuel, afm or anything and they were working quite well at this boost level..
I am curious to see what it will do when i finish what I want to do with it, just a few more minor mods.
AFR's were good to between 11.8 t 12.0.
Well done
i like more auto's having a crack.
good effort on safc etc but that turbo is certainly a pig.
The Auto Hack Paul was talking about isnt realy a hack or anything technical.
simply un plug the brown connector down behind the drivers side head light and it will lock the trans in 3rd gear.
once your finished on the dyno plug it back in and away you go. 1st , 2nd , 3rd..
i notice your dyno was done in drive so it might explain the massive loss in midrange, as he would have to go very easy on the throttle so it dosent kick back to second. thats of course assuming he dosent know about the brown plug.
attached is my old turbo and my current turbo
both running rb25det auto
if you compare midrange power at say 100kmph your not even close.
but both runs on my car are with a PFC but i still think your turbo may be dragging its feet a little..
cheers
Darren
Dangerman,
Yeh he was taking it easy until he would reach a certain klm so it would not kick back, it was constantly kicking back on the dyno...
THe turbo is good for what it is though..i know its no gt30 but I wouldnt call it a pig...on the street im pretty sure im gettn 11/12psi by 3000rpm..
it is annoying though as first gear is wheel spin time.....
I would like to get it run again to see its proper power band...i say ill do it at the SAU dyno day, take that brown plug out..
Midrange does suffer a little on the dyno graph but I dont think its reflects this when drivin in real life conditions on the road..
I would get a PFC if I had the money, but as you can see per the mods I havnt spent much at all..a budget build you could say..
Im still wrapped with the power...
Cheers
Does any1 rekon the boost 98 from united helped me along at all...
Im quite interested in fuels and their advantages and thats the reason why I choose the boost98 as it has sumting like 5% ethanol in it...Ive read quite a few articles claiming its miracles, the ethonal that is and how it has to be tuned to it...
Before I got it tuned i used bp 98 and boost 98..untuned the bp98 felt way better, the ethonal decreased power.
I wanted to use shell v-power racing but I cant even find it in sydney yet...
Let me know your thoughts...im still wondering why the power was so high..the dyno is a pretty average reading dyno(DD) aswell.
Cheers
Looks like a BOOSTD style Hiflow, low boost and cliff like power curve. VG30 rear housing and a highflow front wheel on the stock RB25 turbo.
REV210, what are the specs or how do these BOOSTD turbos rate? all I know is that the previous owner said it is rated at 450hp?
Also with the power curve I dont think it represnts it well as the tuner had to bring it on slowly to avoid it kicking back a gear..I will do the mod where it locks in 3rd gear on the SAU dyno day and then see how it goes...
Also you know the goods on fuels, what is your view on BOOST98 from united petrol..did the ethanol help?
Cheers
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
