if its S1 R33 i think it would be the same as the R32s and its 0.6-0.9 Ohms.
and also check for cracks in them
ended up bein cracks in em, car runnin great at 13psi now. thanks for the help!
cheers
Hey guys another missfire problem.
I have a S2 Gts-t was told by two different shops that it wasn't coils and also had a new cas put in which fixed nothing i had the ecu gone over and everything was fine i had new plugs put in and had the mechanic look over afr, is there anything i can do to try and fix this problem. Cheers
Interested in what you did to resolve this issue?
simple fix, just pull the coil packs off and wrap some flame resistent electrical tape from the plates at the top down to the rubber that clicks onto the top of your plug. it will make sence wen you pull them off. obviestly this is a quick fix. new coils are the textbook way to rectify the problem....
hope that helps.
brett
hope that helps.
brett
hope that helps.
brett
hi guys does anyone have any pics of how you tapped the coil packs i tried searching but no luck,thanks.
what boost? could be hitting fuel cut but im guessing you have allready thought of that... check the coils yourself, cracks are barely noticeable and will not show that they are stuffed wen doing a resistance test on them. if you pull em off you will see a series of plates, cracks occor in the plastic just below that, its caused by heat under that valley cover that comes on the 20's and 25's from the factory....
worth a try before spending much loved coin trying to diagnose the prob!
hope it helps
cheers
its pretty easy mate, if you pull 1 off you will see, its just got a series of plates and a plastic box (kinda) underneath. whem lookin at mine the hairline cracks were in the plastic bit. doesnt really matter where you tape up, as long as you can get em back on and bolted down. its really just a quick fix to find out if you need new coil packs!
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
