IT'S TIME FOR ANOTHER PIZZA CRUISE
register now and i'll start a list.... DO IT!
Friday May 18th
Meet: Chatswood Chase Car Park, Enter off Victoria Ave
Time: 9:00pm, Leave by 9:30pm
Destination: Palm Beach via Newport for Pizza.
Bring: CB's, a full tank of fuel and a good attitude.
Please dont do anything silly as we are on public roads.
Leave all that shit for the track
Pizza Place:
Lucky's Pep'e Pizza Bar
Shp2/ 303 Barrenjoey Rd Newport 2106 (02) 9979 1756
IN SO FAR
Marsss
Primordial
SECUR1TY
rukus
Blitz
Liz
JETR32
mike1987
burnsie
lingeringsoul
NXTIME
smasha
DRD-OOF
D_I_F
N1 R33 GTR
traman18
Dj Albert
Miss Turbo
Nismo_God
LOOF
SAM916
https://www.sau.com.au/forums/topic/165561-pizza/
  • Replies 227
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
