  • Replies 227
I was hoping to bring a friend along to the pizza cruise but they can't commit. I thought it might be a bit boring to drive there by myself so I was wondering if I could scab a lift with someone OR would some other people like to come in my car. I can pick people up or leave my car at there place or whatever, I'm flexible.
Josh
https://www.sau.com.au/forums/topic/165561-pizza/page/5/#findComment-3119364
myself +1 passanger are a maybe, only found out about this today i should look past the hornsby thread more offen.
I'll know later tonight if im a definate
You know you wanna!!!!!!!
I'm in 4 the sin, meet up not to far from home, thanx for makin it easy :laugh: .
https://www.sau.com.au/forums/topic/165561-pizza/page/5/#findComment-3119453
A newbie will be there.
My first OZ cruise.
I didn't know Victoria Rd meets in Chatswood.
Directional Help from Castle Hill.
Hey mate. Not Victoria Rd, it's Victoria Ave. Very easy to get to though. From Castle Hill, get yourself on the M2, turn left onto Delhi Rd then just keep on heading straight till you hit Chatswood at the Pacific Hwy. Drive straight across the pacific hwy into chatswood and from there it's just a few quick turns. Whereis will tell you the rest :laugh:
https://www.sau.com.au/forums/topic/165561-pizza/page/5/#findComment-3119555
My first OZ cruise.
hey mate theres few of us meeting at Kings Park Maccas around 8 815ish, then have a mini cruz up there, im from glenwood so feel free to join us :sleep:
https://www.sau.com.au/forums/topic/165561-pizza/page/5/#findComment-3119999
Holy Fark... nearly 40 lines
I had a chat to a few people at Lucky and Peps on saturday night and told them about the cruise.... (people I know that work there, not the management)
They said "bring it on!!"
Hi5!!!
I was just about to ask if they have been notified lol
https://www.sau.com.au/forums/topic/165561-pizza/page/5/#findComment-3120409
Marssss you have created a monster cruise!
Guys I hope most people bring cb's as it is much easier to communicate in the car.. Try and borrow one of a friend if you don't have one.
Adammmmm I hope you are bringing Bob!
I may bring my sister as well.. She told me last night she loves being in my car.. (Time to take her out on the track) haha
Haha I feel like your PA telling you about these things!
https://www.sau.com.au/forums/topic/165561-pizza/page/5/#findComment-3120636
Considering the number of cars coming, I really hope everyone behaves.
As has already been said, the usual rules apply, ie anyone who is observed acting like a tool will be reported to the police, period.
Aside from the above, this is sure to be an enjoyable night :dry:
https://www.sau.com.au/forums/topic/165561-pizza/page/5/#findComment-3120654
Everyone is pretty much well behaved on these cruises..
Lets just hope they respect the road rules..
https://www.sau.com.au/forums/topic/165561-pizza/page/5/#findComment-3120662
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
