  • Replies 132
ive been receiving emails, at least these last two. site was down for a bit, maybe you didnt get a few (or any?) since then. check out feedback forum and see if anyone else having issues with it
ROM dumping = downloading rom contents via consult (often used when you want to modify ECU with a daughterboars so that you can edit your fuel/timing maps, remove speed limits and such). consult itself is read only, cant remap your ecu with it or make any permanent changes
check out this thread: http://www.skylinesaustralia.com/forums/in...howtopic=143835
no, no problems with r33, so long as whats covered in main post is the case (ie u have stock computer, not aftermarket, havent butchered wiring or done a engine transplant and messed up consult wiring etc).
note: all interfaces are accounted for! (doing this on 3 other forums, which together have covered all available interfaces)
additional people can only get one if someone already on the list pulls out.
since we got close (but not over) the 20+ ($55) threshold:
1) anyone who's donated to SAU will get the interface for $55 incl postage.
2) anyone who hasnt donated to SAU will get the interface for $60 incl postage. ill donate $2 on behalf of each of these people (who havent donated)
note: those who've requested a USB/serial converter, will get their cable and converter after (later than) others, if i dont have time to get the usb/serial cables done as soon as the cables (which my brother will most likely be doing)
here's some pics. can see the bags of pcb's i just received back from manufacturer today. have a few more parts coming in next week. each cable has two pcb's which "stack" on top of each other inside the connector (left one goes on top of right one as shown just above the two sets).
ive contacted first 2 people for payment.
more will follow in next few days
Payment Sent via Bank Account. Hopefully won't take the normal 2 days otherwise it will be that at the most.
Drew.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
