Someone here posted that it is basically the same and uses the same piping but it's just thicker. If thats true then it would be a reasonable upgrade for someone like me who is only planning on running about 12psi max with the basic sort of mods to get around 200rwkw. So for the couple hundred? or so it is much cheaper than a fmic as i wont be running a bigger turbo so i wont need one. So it would provide that bit extra cooling without going overboard on a fmic. If someone could confirm that its a straight swap that would be great, also does anyone have a rough price for a second hand one?
the stock r33 unit hasn't prevented me from getting as much power as the factory turbo can produce.
So far my power output matches or exceeds a fmic, stock turbo combination.
You get to a point where the factory turbo just acts as a blockage anyway.
  • 1 month later...
I doubt you could get them for $100..If you can then you're laughing..
think about it..
REV210 is still running the standard cooler on his car and getting close to 12 second pass (or maybe already done it) and has who knows what power at the wheels.
these intercooler are on a car that already has 206kw and just as the R33 ones can handle some extra power so can these so it would be a great upgrade for someones R33 or R32 who is not looking at getting more than say 250kw at the engine... or maybe even a little more..
I think that these are worth closer to $300 from some that I have seen.
good luck.
Originally posted by MIC33R
If you were offered a FMIC, rev, would you take it and install it? I think you'd be quite pleasantly surprised :mad:
If I was offered a FMIC I'd take it.
Then I would sell it.
And have some underdrive lightweight pulleys made for the engine, perhaps also install an automatic gtst's diff center with the 4.3 gears and buy some decent wide tyres for the back with the money from the sale.
I am pleasantly suprised to beat the pants off all the poor people who got oversized frount mount intercoolers for their stock turbo'd cars (BoostD is the exception to the rule). So in the pleasantly suprised stakes I'm already pleasantly suprised at how little money I've spent.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
