  • Replies 78
i agree stock turbos sound shithouse with a screamer pipe, a big external wastegate though venting to atmo sounds AWESOME but just in regards to the fines.. i recently went over the pits, no cat and screamer... nothing wrong.. and also my mate 04RNZ in an rx3... t66 high mount turbo, no intake pipe/filter, no mufflers, screamer pipe, went over the pits and was out as quick as he came in and nothin happened to him... i think nsw is a little tougher as i lived there, but still out of all the car enthusiasts i know, and deal through with work, i have never seen/heard a fine issued that big.... i do remember seeing a guy get done for excessive noise, but no EPA fines..also my bro inlaw just had his screamer pipe put on his rx7 and got pulled over, nothing came from that, and everything was fine...
ben...
Edited by 2BNVS
ok everyones bitchin about stuff, i know of two people who have had $9000+ dollar fines for screamer pipes they are a major defect which requires the vehicle to be returned to stock before it can be driven again....
Your mates got reamed then. How can they require you to return your car to stock because ONE thing doesn't comply. You are required to make the defecting thing comply with the law and that is ALL you don't have to rip off all your other legal mods just because you got done for one thing. If the two people you know did do as they were told they were very ill advised. The police cannot require you do remove modifications that are legaly applied simply as punishment for breaking a rediculous EPA law. I say it again atmo screamer pipes off large turbo's/wastegates not only sound tough, they give less restrictive flow....same goes for exhausts. Straight through is the only way!!!
+2
I swear so many people on here know someone who knows something who did something who received something, so many missed guided people
how can you tell if your cat is gutted? had the exhaust off when i changed the gearbox and it looked awfully empty... :P
Maybe just weld the cat heat sheild to the pipe so it looks like there's something there :(
Also screamer pipes & 2 flames FTW!
But turning a stock turbo to screamer is the gayest thing since brokeback mountain
1.) if this is for sound, just loosen one of your dump pipe bolts..
the gasket will burn out on that corner and you will hear the same stupid god awful screaching sound of an exhaust leak... this is exactly how a stock turbo, internal wastegate to atmo will sound.
2.) I work for QLD Police.... they can and will fine you the $10K...
As with any cop.. it depends on the individual cop who stops you. and your attitude at the time.
I train with a couple of them who were so annoyed with the individual driver with a bad attitude that they made an example of them..
Also, unless you have an engineers certificate for "ANY" modification from stock, you can be made to remove it.
so the guy above where his mates had to return to stock is very much possible.
de-reg and dodgey road worthy will be and has been found out before too.
that caused a larger fine than the so called mythical $10K fine..
make of this what you will.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
