Eoi: Breakfast Creek Hotel Tuesday Night Dinner (1st May)
Details:
Tuesday night (1st, May)
Booking is made under the name Skylines Australia, at 7PM in the Beer Garden.
for anyone who does not know where it is, here is a full adress
2 Kingsford Smith Drv, Breakfast Creek, QLD, Australia, 4010
you can look it up on www.whereis.com.au
  • Replies 53
just a thought came to my head, a bit of steak would not hurt after twe pastas in a row. some believe they make the best steak in town
anyone against it? anyone up for it?
cheers
BC FTW
ill ring up and find out how the booking and everything works tomoro.
meantime ill start a list of people who are up for it:
me
Bunta (Anna as well i assume????)
GTRGeoff+1
FineLine+1
mrbenno
phatboi2010+Linh
~Prinny~+Spilmer
Chris ( GTS25T4door)
Karen+Revhead
NismoKnight
Dave+1
Shanef
LBR33
LIL34+1
Just updated your title there Franky (date)...
Ill be in MT Isa next week so unfortunatlly im out, but i did got to the BC 2 weeks ago and had the Wargieo steak ($38) and it was great...
Just watch the pricing, you wont get out of there for less than $40 a head with a drink or two and they will only accept one bill per table...
thanx
does everyone think the price is okay or we should go somewhere else?
me
Einstein
Bunta (Anna i assume????)
GTRGeoff
Did you think I was kidding. :P
Dont worry about the price Franky, you only live once... :P
Id be there in a heart beat if I could, just be aware of the single bill...
Side note: The steaks start at about $25ish and work there way up to $55, so there are reasonable priced steaks also.
good well we just have to make everyone bring cash
Col wtf are you talking about. You pay individually for your meal as you order it and buy your own drinks from the bar. ???????
If you book a table Noel you dont get that option, you get a waitress with a pad and pen to serve your table.
The old look at the meat and order and pay system is in the old part of the hotel, where its all 2 to 4 person tables.
Maby ask to book a table in that area, its called the Spanish Garden I think...?
Thats the only place I use col. oh well. we have booked large tables in that area previously so maybe it can still be done. what will be will be.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
