Heya guys,
I'm not sure if this has been covered before but the +/- on the steering wheel for shifting in series 2's.
Mine doesn't work because I doubt it's been wired up or anything. I was wondering if this is with every stock S2 or is it just me? (bought my car blind from over east.)
Just wondering if it is indeed wiring, or is it something else? =\
Any input would be greatly appreciated :rolleyes:
-Dervish
https://www.sau.com.au/forums/topic/166003-series-2-steering-wheel-shifting/
Heya guys,
-Dervish
You need to press the button in the centre console (near where the handbrake would normally go) that has a picture of a steering wheel on it. This button is used to turn the steering wheel buttons on/off. A little pic of a steering wheel will light up on your dash.
Also you need to be in tiptronic mode for it to work. It will not let you change gears manually (either with the gear lever or the steering wheel buttons) unless you are in tiptronic mode. The gear you are in will then also show on the dash.
Hope this works for you :unsure:
hey thanks SO much for that! We have not as yet received our stagea.. but saw that steering wheel button on the dash and I did wonder what it was for. So that button turnes off the buttons on the steering wheel hey? One more mystery solved ! Thanks again
Hope this works for you :D
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
