Hey guys, decided not to go ahead with my stereo install, so I'm putting it all up for sale.
All of the items for sale are BRAND NEW, and have never been installed, or wired up. Everything comes in its original packaging.
1. Pioneer bridgeable 4 channel amplifier - $250
-120W x 4/300W x 2 MAX POWER
-60W x 4/150W x 2, 20Hz-20kHz, 0.2%/0.8%THD,4Î
-LPF (80Hz, -12dB/oct)
-HPF (80Hz, -12dB/oct)
-RCA OUTPUT (FULL RANGE)
2. Pioneer mono power amplifier - $300
-500W x 1,4Î/800W x 1,2Î MAX POWER
-250W x 1,4Î/360w x 1,2Î 20-240Hz, 0.5%/0.8%THD
-LPF (40-240Hz, -12dB/oct)
-BASS BOOST (50Hz, 0-12dB)
3. Pioneer 16cm 2-Way 250 Watt Component Speaker (Competition Series) - $350 **SOLD**
-16cm 2-Component Speaker System
-250 Watts Max. Power Handling
-Aramid Fibre + Pulp Cone Woofer
-25mm Polyester Fibre Soft Dome Tweeter
- Woofer [Midrange(Midbass)] Diameter: 6.5 inch
- Tweeter Diameter: 1 inch Soft Dome
- Impedance 4 Ohms
- Sensitivity 90 dB/W (1m)
- Frequency Response 25Hz to 32000Hz
- Gross Weight 3.24Kg
4. Pionner 16 cm 4-way speakers - $100 ** SOLD **
-4-Way Configuration
-260 Watts Max. Power Handling
-50 Watts Nominal Rating
-Frequency Response 30 ~ 33,000 Hz.
-Efficiency 91 dB
-Impedance 4 Ohm
-f0 (Lowest Resonant Frequency) 80 Hz.
-Crossover frequency 5,000Hz
-Mounting Depth 57mm
-Dimensions 171 (diam.) x 84mm
-Weight 1.84 Kg per pair
5. Pioneer 12" C-Type Subwoofer (1000W) $100
-Composite IMPP cone using interlaced Aramid fibre with reinforcement arcs
-Wide-roll, 3-layer fibre woven radial surround
-Dual mass high power magnet
-Extended and vented pole yoke
-Enclosure use
-Ohm Rating: 4Ω
-Frequency response 18 - 500 Hz
-Sensitivity (1W/1m) 89 dB
-Recommended sealed enclosure (Litres) 24 - 49.6
-Lowest resonance frequency (FS) 32.6
-Maximum input power 1.000 W
-Nominal input power 400 W
-Woofer size (cm) 30 cm
Everything available separately, or take it all for $600
https://www.sau.com.au/forums/topic/166326-fs-pioneer-car-audio/
