Very nice...
Soarer TT... he posted it up in the for sale section... has a vertex kit on it.
Shes pretty much sold on it :)
How embarasing... my quiet as a mouse gf maybe having a faster car than mine... FOR NOW! :P
funniest thing was ringing up and getting a quote on insurance... shes nearly 25 (2 months away) with a spotless driving record and im only 22 with a speeding fine and on the same rating with RACV theres like 200 dollars difference between the 2 quotes LMAO. She was expecting to get insured for like a grand at the max haha
another thing was i got a quote with that soarer in my name and got a quote of 2500... asked for a quote on a GTR (1990 cause 89s arent in the list) which has the same sized engine almost, same amount of turrbos, technically the same power but the GTR i quoted has less mods and it came up with 2900 for full cover but thats no guarantee that the computer will accept it. Ghey arse double standards.
  • Replies 46
Guest INASNT
i been looking at cars for my gfriend for the last 3 months!
FTO's, Pug 206 GTI, Proton Satria GTI, Supra (laughed when she drove 1 for the first time coz she couldnt see anything properly), Vectra, 300zx, Mazda 323 SP, and i am quite sick of looking at em all now.
Guest gtst88
INASNT,
if you dont mind me saying Satria GTIs are crap.. I'm sorry to say that but i come from Malaysia and they are everywhere but this is not the problem .. sure its Torquey but its just not the best bang for the buck ..
i'm sure there are much better cars in the market than a GTI .. and besides its a Proton ! you guys know how dodgy protons are right ? their sales here in Australia is so low, they are struggling with it ..
just my opinion though .. just dont want you and/or your gf to regret ..
inark,
soarers are sweeet !!
cheers guys !
Guest gtst88
Originally posted by INASNT
gtst88
i know i saw 1 drove 1 and then said no farkin way u r buying that crap
yeah man .. i know what you're saying .. they are just not worth the money .. for the price you pay for an end 90s design with crappy 4G93 engines .. and the interior is another joke !
lol doxx... if she does get it i will definately have to upgrade to something faster... altho (sinful as it maybe) i have been looking at NON nissan alternatives to my GTST
*dodges the stones*
I saw that Soarer josie was looking and a few weeks ago and thought it was a pretty good deal.. should grab it.
*dodges the stones*
NOOOOOO! no matter which car my next one is it should be a nissan.. What alternatives u been thinking of nark??
pred -
RX7 TT series 6
96 GTO TT
98 Legnum VR4 TT
something a little more "exotic" and rare that i can see for an extra bit of cash.... i was thinking of getting my mum to bring me one over in a year and if i get a GTO i can sell it for an extra 20k... same with the RX7. Then maybe look at getting an R34 GTR
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
