Supporting mod selection such as cams, manifolds turbo, exhaust etc will be the key to putting the power where I want it. ( and that isnt where you have it) Time will tell if i am right or not.
Question tho;
Where do you want the power???
Where do you think my power is???
  • Replies 185
Posted Images
Strike! Knew i would get a bite Col. :P Wait till I get my tune. I want to work with the tuner on the power curve.
I do no not want a light switch. Even though the hp will be up there I still want to have it come on in a linear fashion albeit at a higher plane than I originally intended. Projected power is going to be in the 350/400 rwkw range so we will have plenty to play with with regards to where we put the torque curve. Its going to be very interesting indeed.
my rb25 made 490rwhp with HEAPS more to go, and full boost by 3800rpm... I reckon you'll be on the ball pending turbo
Turbo is definitely where its at along with cam selection Josh. I still havnt made a final decision on it yet. No hurry tho. I have to amass some more funds now. What are old gigilos worth these days. :P
Yeah, half the battle is in the boost controller Noel
I have have it like a light switch or I can have it gradual...
At the end of the day it does not make more or less power, it just makes it more streetable around town and more comfortable to drive...
Will be interesting to see who hits a 10 second first :P
I think they are somwhere around -$5 per hour
The slapped out whore's around here charge out @ $132 for the first hour, then a discounted rate for the next. I reckon we put you in a suit, and BAM. We have our selves a $100+ man :laughing-smiley-014:
I will
You're assuming that I can last an hour Josh!. :laughing-smiley-014:
The battle to the 10 second quart is it, I say you'll need more flow :P i recon turbo choice change noel The GT 35R or T04Z bah meh im out catchya all tommmmmmmmoooorrow
I did a 10.8 on two HKS GT25/30's, flow my ass.. they are baby turbo's!
It's more about the overall package to be honest
A GT 30 got col to 131mph looking at some times here of other R33s tells me that if Col can get a 1.7 sec 60 footer he should be able to run a 10.8
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
