  • Replies 185
Posted Images
i'm laughing out loud right now....no seriously, really hard. You reckon you can rev your standardish 32 GTR to 10k safely?? I wanna see pics/vids of this....
I apologise to Noel because this does belong in another thread....so mark I challenge you to create one and tell us the mods your car has that allows you to rev to 10k??
lol.. opps meant for the other comment rev to 6500rpm + 2500rpm. or whatever someone said..? lol i never said it reved to 10,000rpm (or did i..?... NO i never said 10k..) thanks matt.. but im sure a IS200 could..?
pics of polished bits noel.. :D
Sorry, just assumed you could add. I'll attach the quotes for you from the previous page:
7500rpm and dump... IMHO
i still can rev 2500rpm higher than that... :P
Might just be me but 7,500 + 2,500 = 10,000???
I doubt it, but unlike you I never claimed it could, did I?
Latest update on build...Tore the bottom end down today. (Thanks for the help Shane) Immaculate. Its a pity to discard some of these bits but! Ordered. and on the way. Eagle rods to replace peened cryod stockers. Jun oil pump, 6 boost himount manifold. Cams. heavier valve springs, Head is going in for solid lifter conversion as soon as the cams and springs arrive.
Cam specs Tomei solids. 260 duration, 9.1 lift.
What started out as a mild street machine has turned in to a monster. Now looking at figures in the 350/400 rwkw range.
Some f**kin wheelchair. :P
no probs old fella, something to do to 'waste' the arvo away :P (i really only do it for the rumbo's ;))
i still reckon it's gonna creep on the 500rwkw figure @~24psi
shit left would be fueling, gate, & bov and thats the main bits catered for! ;)
smy thread so I can say what i like. ;);)
fair enough then lol
So "dry sump" so you can rev the tits off it is normal huh. :P
only a few ways i'll be able to get the rb30 to rev and 1 is dry sump, the other is 2+k of machine work >_<
well nengun has these 2
http://www.nengun.com/nismo/fuel-pump-skyline (276l/h)
http://www.nengun.com/hks/fuel-pump (280l/h)
i reckon one of those 2 (i like nismo over hks) would be good to feed the surge tank, than a big yank pump feeding the fuel rail :P
You dont need to go that fair Noel...
A good old Bosch 044 fitted in the tank with a raising rate reg will do the job and keep it legal...
that's dodge/cheap and you know it col lol
why play on a knife edge with a big $ engine combo for the sake of a few hundred on a fuel system, it's a no brainer in my opinion
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
