Hey guys
About to put a deposit down to get some 18x10 rays gtc's but wondering what offset I should go for, for my gtr32. I was told that the standard offset looks pretty tame when put on the car, but I want the tyres sitting flush under the guards! Planning on going 265/35 all round. Any help would be great! And pics of cars wit the same width rims and tyres would be sweet cheers!
Steve
https://www.sau.com.au/forums/topic/166798-18x10-rays-gt-c-on-r32-gtr/
sorry to keep hijacking your thread phat25t...
The dude down at bob janes seems to think they wont fit. Im not sure what offset would be required? Im also not entierly sure what offset is... I understand 255 is width, 45 is profile and 17 is rim size.
is offset distance from the center of the tyre from the center of the hub?
The guy at bob jane didnt seem to think the problem would be with the width but with the height...
he's probably right. a 255/45*17 will be about an inch larger in diametre than a 255/40*17. The 255/40 is about the right diametre for an R32 GTR.
yes, offset of the wheel is the distance from the centre of the wheel to the mounting face at the hub. bit of a recent discussion about offsets on R32 GTR here
Edited by hrd-hr30
Hey guys, sorry to hijack, but my work meister s1s are 18x9.5, offset should be ard +20, basically i had 265/35/18 on them and they sat flush with the guards, no problems wotsoever. i'm wondering if 275/35/18 will clear the front n rear guards? Please advise.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
