Hi people
just wanted an opinion on how muck power my car will make, the rebulid has the following and i intend to put 600cc injectors and camgears to increase boost response. so please tell me your opinions and what would be a good rpm limit for the car as well as how much boost do you think i should run her on??
ACL Forged Pistons
ACL Piston Rings
ACL Big End Bearings
ACL Main Bearings
Ported and polished head
Stock polished crank and rods
Bored and honed Block
N1 Oil pump
N1 Water pump
Tomei Oil Gallery restrictor
Gates timing belt
New engine gaskets all round
New Thermostat
New NGK spark plugs
R34 GTR injectors
R34N1 turbos C106/GT25 A/R 0.60/0.64
New Rod bolts, welsh plugs
Fresh paint on rocker covers
3" Trust Front pipe and Power Extreme II Cat back Exhaust
3" Metal cat
Twin Apexi Pods
Apexi Power FC & Hand Controller
Greddy Profec B Spec II boost controller
Nismo fuel pump
Heavy Duty clutch
Thank's in advance guys
anthony
https://www.sau.com.au/forums/topic/166916-r32gtr-rebuild/
Sounds like a nice spec to get some good power. I would also look at the fuel pump and perhaps upgrade that as well.
With all that in place you should see around 550-600bhp at the fly. I wouldnt rev much past the 8000rpm limit as N1 oil pumps dont like high revs plus you are keeping std rods. Saying that, with good mapping the engine should last for quite a while but i would run a compression test every 4 or 5 months to ensure everything is fine.
I would also look at a sump extention with baffles.
Gez
https://www.sau.com.au/forums/topic/166916-r32gtr-rebuild/#findComment-3088688
320-350rwkw is pretty much what everyone else makes.... So you wont be much different.
Mainly dependant on what dyno you use than anything else. :P
So for the boost etc, talk to your tuner.
I hope you used decent rod bolts though
https://www.sau.com.au/forums/topic/166916-r32gtr-rebuild/#findComment-3088741
To be honest nismoid i didn't do the rebuild i bought the car with all that stuff and it was making 250awkw on 14psi so i don't really know what rod bolts ere used.
but the do usually upgrade them don't they, when they do the rebuild??
Cheers
anthony
https://www.sau.com.au/forums/topic/166916-r32gtr-rebuild/#findComment-3088880
sounds fairly similar to my rebuild i just recently had done. my cars making 239.8rwkw's on 14psi.
im running a haltech e11v2 with boost solonoid and 3bar map sensor.
r34 gtr turbos(non steal wheeled, hence only 14psi)
should make 400awkws with the correct bolt ons id say with ease(not talking bout my car). ie bigger turbos, injetors, fuel pump/s, decent ecu, cooler etc.
ill rephrase that, that bottom end should handle 400awkw's
Edited by Turbz_13
https://www.sau.com.au/forums/topic/166916-r32gtr-rebuild/#findComment-3092290
Get a pair of Z32 AFM's and a bigger pair of turbo's, that engine should easily handle into the 400's.
With good reliable tuning, proper support systems, i agree. For how long is the real factor, determined by use, bearings etc. A dead injector, failed pump, faulty rod bolt will spoil your day regardless.
Nice build man, envious !!!!! :blink:
https://www.sau.com.au/forums/topic/166916-r32gtr-rebuild/#findComment-3092955
Anthony you finally brought a real car :rofl:
Yea finally but i have to change the clutch and after that i can really enjoy it.
By the way guy's the turbo's that i have on it are the bigger r34 n1's .6/.64 so how much power can those turbo's make??? also when should i see about 1 bar of boost with these turbo's
Cheers
anthony
https://www.sau.com.au/forums/topic/166916-r32gtr-rebuild/#findComment-3094614
The N1s are the Group A versions which is what I have running on my wagon. Your set up is quite similar apart from your lack of cams and wheels. I made 500.9rwhp or 373rwkw at 23psi. The motor will take more and the turbos have a bit left in them but for reliability 23psi would be up there as a max.
https://www.sau.com.au/forums/topic/166916-r32gtr-rebuild/#findComment-3094840
So is this the same turbo's that i have cause everyone's been telling me that it will make a max power of about 310 rwkw. is that true??
Cheers
anthony
https://www.sau.com.au/forums/topic/166916-r32gtr-rebuild/#findComment-3103417
I know that my turbos are the N1 Group A, same AR's as what you have stated. The advice you have received is incorrect or there are different boost levels being quoted.
well as far as i know my turbos are the r34 N1's i don't know if there group A's
by the way what rpm do you reach say 1 bar of boost, and do you have any idea when you reached 1 bar without the cam's??
Cheers
anthony
Edited by black sky
https://www.sau.com.au/forums/topic/166916-r32gtr-rebuild/#findComment-3108122
I did a full rebuild and upgraded the turbos, cams, wheels, injectors, afms, sump, pumps, ic, oil cooler everything all at the same time. 14psi is reached around 4600rpm with 23psi coming in around 5000 so its a bit of a light switch.
https://www.sau.com.au/forums/topic/166916-r32gtr-rebuild/#findComment-3108399
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
