Hmmm...protech seems nice. But u sure they use zymol products??
yes, they are a licenced re-seller and use their products on the better packages. The lifetime package is quite expensive, 25k or similar they told me.
I have a bottle of the zymol quick shine stuff (pink) smells and works fantastic for a quick shine.
Zymol are one of THE top brands...
Their top wax, Zymol Royale..., thousands of pounds
Zymol do make some ripper products, as do..
Swissol
Zaino
Menzerna
Optimum
Poor Boys
P21s
Aquatouch (MF products)
Polylack
Some brands do better jobs than others, some cross-over in what they offer. Eg, Menzerna have some of the best polishes you can buy.
Once you get heavily into these top products, it's more personal preference on the way the paint appears, than what's better. Some can give a super optical clarity at the end, but some people prefer a deeper, warmer glow, look.
EDIT: Final Inspection use any of the above, but use the best product suited to the car as some suit different colour cars more-so than others. You'll always get THE best products used on your car, even if it's just a Stage 1 exterior detail
Swissol
Zaino
Menzerna
Optimum
Poor Boys
P21s
Polylack
Daniel i agree although i have never used Zymol products they are very top of the range and extremely good.
I have looked into them and to get a kit to detail a car well would cost approx $800. Now i have no idea how far that 800 bucks kit would get you but I'm tipping not overly far.. so makes for a very expensive detail.
Swissol
Zaino
Menzerna
Optimum
Poor Boys
P21s
Polylack
I just had my car deailed with Menzerna wax, infact I grabed a couple of litres for home after seeing how good it really is!! I couldnt believe the difference the product makes even between the top brands..
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
