Well guys....it's on again, Our entry forms go in tomorrow. Due to the day being changed from Sun to Sat we have lost 2 of our drivers so Mick and I will be going it alone this year.
We did post in the Qld forum looking for another car and driver or 2, but no takers.
We need a new set of tyres The O32R we ran last year are not available,and, it's proving dificult to get anything else in the sizes we want.
We are now thinking of going full slick and praying for nil rain on the day (yes, it did rain for a short while last year)
Has anyone tried out Dunlop D11s...that would seem to be the choice, 265 on the back and 240 on the front
cheers Jay
bugger, I have missed this again this year....hoping to drag the car up there next year.
The yoko a032r weren't great tyres so dont worry about them....what size are you looking for? Dunlop DZ03 were the tyre of choice at Targa, other decent ones are bridegstone re55 (if its pretty dry) or toyo 888. yoko a048r replaced the 32 and are probably available but they are just as expensive and bad
Good luck Jay
Duncan I'll post a bit earlier next year. Maybe we could team up and run as Team Skyline Racing :blink:
We have 17x81/2 front and 91/2 rear can't get over 255 in anything. So we are thinking of the Dunlop D11s in 240.625 front and 265.625 rear.
i'll have to check if any of my friends are bringing their porches out. Wayne was meant to bring his 996GT2R out last year but had overheating issues in the test sessions building up to it so pulled the pin.
like last year it looks like a good event. wish i could be up there (and have a car to run)
good luck 51jay
hmm I've never had the pleasure of running on new slicks (although I do have a set under the bench I am itching to try).
But I get the impression they won't be worth more than say 1 sec over semi slicks, and you run the risk you will have to watch everyone else driving around if it rains :P
Anyway, let us know how you go, good luck!
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
