I think all JDM imported cars are tuned to run on 100 RON fuel as that is the lowest RON rating fuel they have over in Japan. Correct me if i'm wrong...
In saying that, I've never tried Shell's 100 RON fuel due to it containing Ethanol. They use Ethanol just to bump up the RON rating. Unless your car has been designed to handle even just 5% Ethanol, you are killing your fuel lines and engine.
Edited by gel
Research in to it a little more you will find 5% is perfectly fine.
Hey Guys,
Below is a quote from Sydneykids very extensive testing on the Shell 100ROM ethanol mix. I hope that this will silence the critics for the last time in regards to any supposed corrosive element within this fuel.
February 2006
We have a new project car, an R33GTST that is in need of some TLC. One of the recent upgrades was a Power FC. As most people are aware, the default ignition maps are a little advanced for Optimax, Ultimate or Vortex 98. Not as bad as they used to be for 95 ron fuels, but still a tad. Obviously I will tune it properly eventually , but we have a few mods to go yet and I don’t have the time to tune it multiple times. So the idea was to stick the Power FC in and run it on the default maps for a couple of weeks. On Optimax and Ultimate (didn’t try Vortex) it was reaching knock of 60+ up our usual test hill in 4th gear as logged on the datalogit. The dash warning was also flashing frequently, as it is set for 60, in normal day to day driving around. When the tank was just about empty this week, we filled it up with Optimax Extreme (@ 5 cents a litre more than Optimax). Several runs up the hill and we are not seeing knock over 10. And zero dash warnings in 3 days of normal driving.
Now that is very worthwhile, there is not enough Optimix Extreme around yet for me to tune it exclusively for 100 ron, but it sure will be a useful for the odd track day or run down the ¼.
I will monitor the effects of the ethanol on the fuel lines, o’rings and seals over the next few weeks. The injectors and fuel pump will have to come out shortly so I will check their condition as well. I am not anticipating any problems, but it is still worth checking.
March 2006
After a month (~2,000k's) of running exclusively on Extreme in the R33GTST, I did a fuel filter change on the weekend. Cut it open and no sign of any foreign material, deteriorated fuel hose etc. That means zero effect from the 5% ethanol, as expected. So we will continue to use it.
Current status, after 8 months of running exclusively Shell Optimax Extreme 100 ron.
After 3 fuel filter changes I still haven’t found one sign of fuel system rubber or metal deterioration.
I cleaned the injectors last week and there is not one sign of any effect on them either. I also flow tested them and they performed exactly as they did last time I flow tested them.
Based on the results with the R33GTST, I have now started to use it in the Stagea, which I will be tuning again very shortly to take advantage of the extra performance on offer.
:P cheers :(
Below should answer all the mongs out there who say it wont corrode your fuel lines BUT IT WILL destroy ur engine internals...
Sk. have you managed to open up the block on your R33 GTST? Would be very interested in seeing if there is any discoluration/corrosion etc in the block after running extreme exclusively.
Actually, the cylinder heads is off at the moment, it is getting some new exhaust valves after a 10,300 rpm over rev (wasn't me). Looks beautiful, no signs of detonation, inlet ports are clean and unmarked, pistons and exhaust ports have the right amount of discolouration for a 110,000 k's old engine. The valve seats (inlet and exhaust) were in perfect condition. The Bores are perfect, no lip, still can see some hone marks. The rings look to be doing their job just fine and the standard head gasket was sealing perfectly.
Overall, it's in perfect condition, especially considering we have been running it at 15 to 1 A/F ratios off boost and 12 to 1 on boost. Plus it’s done a few laps on circuits, a handful of 1/4 runs and is tuned with lots of ignition advance. Twelve new Ferrea exhaust valves, o’rings, a quick port and polish of the combustion chambers and it will be ready for some more work.
:O cheers :(
For anyone else who is not convinced by the above please use the search menu (maybe a good idea to filter by Sydneykid) to see the extensive testing that has gone on to prove that Shell 100RON V Power Racing/Optimax Extreme is an awesome fuel for skylines. The standard ecu loves it...the only thing to watch out for is for cars that have already been tuned for another fuel via a pfc etc etc may need to get a retune or a checkup on the dyno.
SK...thanks again for doing what you do.
that is a complete urban myth. the lowest quality fuel in japan is not 100RON, and not all japanese cars are tuned for 100RON.
* going to the shell...
will update when i get back to a computer :P
It's not available at all Shells. You want V Power Racing and not just plain old V power.
Coles Express Carlton 277–281 Princes Hwy, Carlton, NSW
Coles Express Darlinghurst 47 Flinders St, Darlinghurst, NSW
Coles Express Dundas Cnr Kissing Point Rd & Kirby St, Dundas, NSW
Coles Express Fairfield Cnr Polding St & The Horsley Drv, Fairfield, NSW
Coles Express Green Valley Cnr Cowpasture Rd & Green Valley, Cartwright, NSW
Coles Express Hurstville 39 Forest Rd, Hurstville, NSW
Coles Express Kingsford 48–56 Gardeners Rd, Kingsford, NSW
Coles Express Kirrawee Cnr Princes Hwy & The Boulevard, Kirrawee, NSW
Coles Express Lidcombe 18 Parramatta Rd, Lidcombe, NSW
Coles Express Marsfield Cnr Epping Rd & Culloden Rd, Marsfield, NSW
Coles Express Neutral Bay Cnr Ben Boyd Rd & Ernest St, Neutral Bay, NSW
Coles Express North Ryde Wicks 96 Wicks Rd, North Ryde, NSW
Coles Express Pymble 21 Ryde Rd, Pymble, NSW
Coles Express Roberts Rd East (Greenacre) 9 - 11 Roberts Road, Greenacre, NSW
Coles Express Thornleigh 188-190 Pennant Hills Rd, Thornleigh, NSW
woah... considering i live in melb, this is going to be expensive :P
we'll try again.
VIC Listings
Coles Express Brunswick Lygon St & Glenlyon Rd, Brunswick East, Victoria
Coles Express Kew Cotham Rd & Cecil St, Kew East, Victoria
Coles Express Laverton Cnr Geelong & Aviation Roads, Laverton, Victoria
Coles Expreess Werribee Park 137-139 Princes Highway, Werribee, Victoria
Coles Express Tullamarine 175-183 Mickleham Rd, Tullamarine, Victoria
Coles Express Jacana 945-957 Pascoe Vale Road Victoria
Coles Express Lyndhurst 180 Dandenong - Hastings Rd, Lyndhurst, Victoria
Coles Express Penninsula Gateway Robinsons & Frankston Rds, Flinders, Victoria
Coles Express Melton South Station St & Brooklyn Rd, Melton South, Victoria
Coles Express Mill Park Plenty Rd & University Dve, Mill Park, Victoria
Coles Express Latrobe Terrace 202-210 Latrobe Terrace, Geelong West Victoria
Coles Express Westgate South Westgate Fwy, Port Melbourne. Victoria
Coles Express Ashburton Cnr High St & Johnstonn St Ashburton VIC
Coles Express Burwood Cnr Burwood Hwy & Central Ave Burwood VIC
Coels Express Ferntree Gully 1140 Burwood Hwy Ferntree Gully Vic
Coles Express Cheltenham Centre Dandenong Rd & Warrigal Rd Cheltenham VIC
Coles Express Richmond 399-411 Punt Rd Richmond VIC
Coles Express Vermont South 602-604 Burwood Hwy Vermond South VIC
Coles Express St Albans Cnr Station Rd & Main Rd West St Albans VIC
Coles Express Doncaster East Blackburn Rd & Reynolds Rd, East Doncaster, Victoria
I have done some work for a EFI manufactor in the past and they did tests using ethanol. Its not to good. It is corrosive!
They had stuffed injectors and all sorts. I got told to stay a way from it.
It is made using sugar, which if enough gets in your fuel tank can destroy a motor. One of the old revenge tricks was adding sugar to someones tank.
petrol is made using old trees. putting bark through your motor will ruin your bores.
sugar is converted to ethanol, after which the fact that it came from sugar is irrelevant. besides, mythbusters tested the sugar in the gas tank idea and busted the sphincter out of it. as for ethanol being corrosive it depends in what concentration and what your car's fuel system parts are made out of. In Brazil they run E85 (85% ethanol) and their cars run fine. A manufacturer just doesn't stick their neck out and say "my car will be fine" unless they have to, which is what is happening here. Sydneykid has been running 100 RON fuel for 12 months and has not had any issues.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
