Its not unheard of. Case in point - The current Holden Barina is inferior to the model it replaces, as Holden have obviously decided a lower priced/lower quality car will better suit the marketplace.
This doesn't apply, as Holden sources these cars from other GM brands, it doesn't desgin and build them itself like Nissan Japan did with the Skyline. Holden decided to switch from the European "Opel Corsa", to the cheaper Korean "Daewoo Kalos", while keeping the Barina name. Nissan obviously didn't do this.
It was not a comparison, I was answering his question but I guess you missed that bit.
Maybe, but it doesn't relate to this argument though does it? So its not relevant.
https://www.sau.com.au/forums/topic/167183-33-vs-32/page/2/#findComment-3105623
  • Replies 67
Seriouly, I BEG that you read before you post things like this.
Smurf said:
Why would a car manufacture release a new model that isnt superior to the previous model?
Holden, have "released" their "new model" barina and it is NOT superior to the "previous model"
He asked a question and I answered it.... And then you tell me it does not relate to the argument.... I WAS ANSWERING HIS QUESTION...... PLEASE FFS don't make me say it again! :rant:
I know that the new barina is sourced from Daewoo but it is still the car Holden have released as the NEW barina!
Edited by r32line
https://www.sau.com.au/forums/topic/167183-33-vs-32/page/2/#findComment-3107149
in my opinion, a R33 puts power to the ground ALOT better than a tail happy, tyre frying R32 does. The R33 feels like a much more stable car and when lightly modified, is still a comfortable off boost daily driver. THe R32 is like a go kart, actually similar to a S13!
https://www.sau.com.au/forums/topic/167183-33-vs-32/page/2/#findComment-3107229
I just picked up my R33 gtst, and after been in mates cars not actually driving them i can notice a diff that the R33 is much smoother
couldn't agree any better there about boost their like a normal car .. IMHO..
Edited by Yme33
https://www.sau.com.au/forums/topic/167183-33-vs-32/page/2/#findComment-3107299
Hahaha, i dont agree with that statement at all. You cannot apply rules like 16% more power but only 6% more weight means its faster... I know the R33 is quicker (in a straight line) but just because one cars power to weight ratio is better than another cars it does not mean that car is going to be faster. How a car puts its power down introduces countless other variables....Tyres, AWD vs RWD vs FWD, Traction control system, launch control.... I wont bother continuing
I did say 'simplistically'. As for how the cars get their power down, I thought we were comparing GTS-t with GTS25-t? Both RWD without traction control/launch control. Both have VERY similar rear suspension (geometry, spring rates etc). We were comparing stock for stock, but I doubt anyone has stock tyres anymore, so we'll just assume same tyres for both, both have same sized rims so that shouldn't be a problem. Both have R200 VLSDs, so they'd both get the power down the same way there. Both have very similar gearbox ratios too. The difference is the R32 has a ~5% shorter diff ratio (4.363 vs 4.083 from memory) which would increase acceleration compared to the R33. But R33 has more torque at the engine to start with, so it's negated, leaving the R33 faster.
I realise you can't use power to weight all the time, but these 2 cars are VERY similar, so in this case, you can and it does work. The R33 IS faster in a straight line.
Edited by salad
https://www.sau.com.au/forums/topic/167183-33-vs-32/page/2/#findComment-3110390
LOL
put an RB25 into an R32 ;)
then you get the power in a much nicer looking car.
sorry just had to say it
But then this whole discussion would prove pointless :(
Coming from a Honda background.. people always go on about Hondas being gay because they are small,light and reasonably qucik. My ITR, was just on 1000kg. Has a tiny 1800cc NA motor and would do 13.8 @ 100mph all day.
Then you get the people in their bigger Turbo cars saying things like " Well if my ****** was that light it would be 10x qucker than that shit ass Honda..." Is it me or is it just them trying to make their penises look bigger? *shrugs*
Kinda went off track. :thumbsup: My bad.. continue :( (would like to add im am currently in the market for an R33.. so im not a Steriotypical Honda driver :excl: )
https://www.sau.com.au/forums/topic/167183-33-vs-32/page/2/#findComment-3138583
Why nissan even bothered to make a 6 cylinder 2 litre engine is beyond me. It just added unnecessary weight to the 32. They already had some brilliant 2 litre engines laying around and should have used one of them.
As for looks, Every time i see a 32 I look for a backward baseball cap in the near vicinity or in the car itself.
The 33 is far more classic coupe design and will be the most timeless of all of them in the long run including the 34. (guess which one I drive) :P
https://www.sau.com.au/forums/topic/167183-33-vs-32/page/2/#findComment-3145039
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
