OK, new plans people...
Cruise now will be up to sorrento, get up there nice and early on a sunday and kick back by the beach, have some drinks/food etc, enjoy the place, and maybe go 4 a cruise on the ferry across to queenscliffe....
Even head to portsea pub for a while...meant to be real nice down there now
sounds like a great day down the beach to me
cheers
jet
https://www.sau.com.au/forums/topic/16735-suggested-bbqcruise/
Shit, I'd be happy to go for a cruise anywhere - I'm still yet to catch up with all you guys!
Haven't been to Skyhigh since they started closing the gates at night - much better going there after dark! Skyhigh would be a bit warmer than Heathcote anyway (was up there last weekend - it was about 1°!)
My only prob is having too many other commitments.... aaargh! ill make it one day...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
