so for a while, ive had this wierd grinding that has come on and off here with a strong humming. lately it has got worse and worse, so eventually i popped the boot and listened to it on idle and as i thought it was coming from the pick up where the fuel pump is.
now i had just recently replaced a f**ked stock one with a bosch 040, even had it installed by boostworx whos a very reputable shop in SA, so its left me puzzled as i have bever heard of one of these failing before. now ive gotta go have a look for the warranty papers :)
https://www.sau.com.au/forums/topic/167602-a-bosch-040-failure/
Hey Stew,
Are you able to describe your setup? Is the 040 where the stocky was? Same pick up height?, sock filter?
Mate of mine had a few let go in his 180 recently. He had heaps of crap in his tank tho lol, might be worth a look.
I'm thinking of late, this is how many die, and how they are getting such a bad rap :D
no. there just shit. lol ive turned blu in the face telling people they just dont work.....
cold ok. hot gay.
Im not sure what hot gays have to do with it, but as long as industry continues to use em, so well I :D
Hey Stew,
to be honest i do not know as boostworx put it in. i can pull it out and have a look if need be. boostworx are a reputable workshop, and it seems to pick up as much as the stock one, if not a bit more.
lol.
yeah i replace them for the fun of it do i???? ever put a fuel pressure guage on one from cold to hot and see the pressure drop down to 10 pound when the fuel heats up? if not your driving a time bomb.
but its ok. you simply turn it off and re-start. and wait for it to start cavitating again.
it was kind of a piss take after how many people always reccomended them saying theyd never had one fail etc.
the pumps themselves dont fail. the way they are mounted is important. if they recieve any sort of air bubble then they cavitate and loose pressure. they still work but they dont operate in fuel over about 30degrees
besides they only put out 10% more than a gtr pump.
To start with, if you didn't have the tank removed and cleaned...and can show proof, then no warranty will be had. Also...who said the pump has failed. Just because it makes a bit of a noise. I have used a fair few of these before without failure on a single one. Doesn't mean it can't happen but it's highly unlikely. The noises can quite possibly be coming from the standard mounting frame which the pump will vibrate against if it has no padding between itself and the pump. Also if they are mounted too low they can vibrate against the bottom of the tank.
Noise doesn't mean stuffed.
yeah. like they dont fail there output just drops off as the fuel heats up. happent to me and 3 of our customers. they pumps them selve ae fine. they just went operating properly.
kinda hard to explain with out a 10 min long video showing exacly what gos on.
th o44 is a gem. no dramas regardless of mounting style
(lol @ spelling,dialing wand needed)
Shaun measures the length and sets them up correctly. So yes.. Exactly the same height as stock.
Bosch pumps do get groany when the fuel heats up. When mine wasn't receiving full volts it was so bad the floor pan would vibrate and could be heard/felt over the radio.
yeh, i read the warranty, bit annoying.
i used a question mark in the title because i was asking a question, i wasnt stating it had failed. it still seems to be working, although i have noticed some stuttering, but in saying that i have fitted an RB25 turbo recently.
its been a deteriorating issue, it has been getting worse over time, now considering i have driven in 43' heat and not had this problem, but now driving in 20' heat and having it worse than ever doesnt seem to make sense. the noise happens here and there, not every time i drive it. happens when its cold (just reached or a bit below operating temp), hot, doesnt matter.
the humming is one thing, but the loud scraping noise is a bit of a worry.
ill take it to shaun and see what he thinks, if its just the noise, im not fussed, but when i hear something like that, i want to make sure im not going to have to be picking up pieces of my engine any time soon.
went to turn on my car today, turned the ignition on, but didnt hear any fuel pump buzz like usual. so went to crank it over, started terrible like usual, did it again and gave it a bit of throttle and it made it. turned it off, tried it again, no fuel pump buzz, cranked it over again, started just as bad again (which is unusual), kept repeating this and never heard the fuel pump buzz, not sure whats happening. the noise wasnt very prominant, but like i said, it happens here and there.
    • Looking to do a turbo conversion on my RB25DE Neo Does RB25DE Neo lower intake work with RB25DET Neo Upper intake manifold?    I found an upper only intake manifold for sale but not sure if it will fit the bottom  half stock intake manifold I have already? Thanks  Also if your selling any parts relating to RB25DET Neo pls reply below or dm.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
