After wtb one last week i have now ended u with two
long story short after no contact from the person i bought one off purchased a second one off nater31 (the d1 project special editon) the day he sent me it i received an email from the first person saying they'd been over sea lol
I've decided to keep the brand new one been it's brand new and i am reselling the other one
It's in perfect nic and i am selling it for exactly what i paid only fair since i paid for it only a week ago lol
$320
i'm in canberra pm or get me on my mob 0420243038
cheers
-shawn
Edited by Darkon
one other note does not include stand or extention plug. It needs to be hard wired niether an issue really
will post for the $350
Hmmm. Dont care about the stand, but what happened to the extension plug? I thought they all had to be hard wired in?
Does it have a tune on it already, or are all values set to default?
Cheers,
Chris
it would have the tune on it from nater31 I wasn't to bothered about tune because it's been put it by the mechanic with my new engine and turbo. as for the plug it didn't come with one nate lost it. The mechanic said this wasn't a problem he would just extend all the existing leads and hard wire it.
they are always hard wired but you can have the option to have the lead from the unit plug into another plug and then to the ecu
sorry mate, i didnt realise powerfc does all this for u, plus i was after a boost controller- my bad
cheers john
cheers john
no worries champ your after the avcr i think it's called
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
