hey all
i hope someone ca help me solve this mystery.
the other night i decided to see how my car would go at really high speeds (now im talkin i got up to 170k) the car did well, held it togther nicely, but............i threw it into neutral to put less strain on the engine as i slowed down.........then she stalled. f*** knows why!??
Im thinking maybe it was cause she was at such high rpm????????? please help! this is so weird! cause the the highest i can go is 180 km so i dont understand why!!!!
https://www.sau.com.au/forums/topic/168340-what-the-f/
  • Replies 49
a car going from almost full load to nothing in less than a few seconds - it doesn't surprise me.
stalling the car means no steering and no braking. glad you didn't hit someone...
try it on the track next time. i dont need to remind you, that you're an idiot.
https://www.sau.com.au/forums/topic/168340-what-the-f/#findComment-3112322
my brakes worked fine.....and i still had full control of the car
https://www.sau.com.au/forums/topic/168340-what-the-f/#findComment-3112330
you know full well that i'm not out on a personal vendetta or anything.
but i'm sorry to say no that you do not have full control of the car.
with the car stalled you have no power steering, and braking is very limited.
that aside, being in full control of the car still doesn't justify it.
i'm thinking oil pressure could be your problem? not sure, i don't know anyone else who would try/think to do something like that.
https://www.sau.com.au/forums/topic/168340-what-the-f/#findComment-3112334
Holy!!! that is dangerous....seriously, I had my car cut out before doing 40k right before a corner and with the car stalled, it is close to IMPOSSIBLE to press down on the brakes or turn the wheels. Count yourself lucky there were no cars in front or a bend because if there were, you wouldn't be here to talk about it.
https://www.sau.com.au/forums/topic/168340-what-the-f/#findComment-3115809
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
