Hey forum just wanted to know if turbo size affects exhaust note. Have a turbo back system on my car and the exhaust note didn't really change got just a little deeper but basically remained the same. Its 3" front/dump and decat pipe and from the decat pipe to muffler 3.5" apexi n1 cat back then a 4.5 inch cannon at the back. I was thinking this would be extremely loud but its just as quiet as the stock muffler just a little bit deeper. Its all tied in to the stock turbo tho thats why I asked if turbo size affects exhaust note. All and any advice is greatly appreciated.
https://www.sau.com.au/forums/topic/168450-exhaust-note/
The Resonator on your Apexi N1 cat-back will have an affect on the noise level of your exhaust, I'm not sure where you are if its legal or not but if you want the car to be loud then you'll need a split dump with a screamer pipe outlet and customise the cat-back so it has no resonators.
If your Apexi N1 exhaust is quiet as stock but deeper sounding then I'd leave it, most people try to find that and never acheive it.
https://www.sau.com.au/forums/topic/168450-exhaust-note/#findComment-3113478
No I love how it sounds just was wondering as I thought it would be much louder. I will soon have another turbo to install and was just thinking if the exhaust note would follow the same pattern. I have a split front/dump with a screamer and when the wastegate opens, "DAMN!!!!" but during normal driving and acceleration the note is excellent just a little bit deeper than stock will try to get a sound clip for you.
Ohh I live in the Bahamas by the way. :nyaanyaa:
https://www.sau.com.au/forums/topic/168450-exhaust-note/#findComment-3113620
Turbos in a way are a muffler aswell. N/A's of the same motor are heaps louder
^ Yup. Anything that stands in the way of the gas flow (and the sound waves that move through it) will dampen the sound. A I6 M3 with a big zhaust is ear splitting.
Replace the second muffler with a resonator, and keep the $ for the fines
https://www.sau.com.au/forums/topic/168450-exhaust-note/#findComment-3122327
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
