  • Replies 55
Or people could just get their own manifold converted, or SAU could have a donation plenum, which would get converted to front facing, then their own plenum would become the donated one. BTW the rb20det is not the same as rb25det. By the way, if your looking for something sexy thatll look good at car shows etc, the converted plenum probably isnt for you, there are greddy ones that probably are.
Yar, but you would be wanting some coin in exchange right? thats usually when the word Keen is used.
SST Steve, how much are these plenums retailing for? Do they just fit on factory runners? Do they have trumpets or utilise angles ? If there is one for the rb20 ill be interested in the future.
Cheers
LOL
anyways fellas I have Pmed both gradenko and R33 impul so all is good. Gradenko lets hope the budget holds out, no cyclones on the horizon up in the northen suburbs
thanks for all the input
i think that it seems like such a simple idea and such an easy install in terms of simplicity, it is difficult to reach but not alot can really go wrong from looking at it hey.
Anyways this can be closed if needed,
hey steve whazz the cost the for the per4manz ones
with the amount of engineering GReddy and other intake plenum designers put into their plenums one would have to assume that simply relocating the throttle body isnt going to work quite as well. but on a budget there isnt anything else
youve also got to ask yourself what saving 1-1.5m of piping is really worth with reference to a cut n shut job
IMHO, yes, its definetly worth removing 1m or so of piping, even if its means using a cut'n'shut. In any case, I'll post a objective review after its done. Specifically looking at power gain after tuning (if any) and change in throttle response. Could also put it on a flowbench to check flow distribution. Anyone know of a place that'll do it at mates rates?
Take a look at 1JZ and 2JZ plenums. From the outside they look remarkably similar to our cut'n'shut job.
its the length of the runner relative to the original position comapared to the relocated position thats important though
ie nissan designed cylinder 1 and 6 (the ones people question) to be the same distance from throttle body, cut n shut the plenum and now its completely different
I'm not convinced Nissan went to any great lengths designing that plenum. Sure, it worked out well that air flow distribution was equal, but it seems to me their number one design goal was shortening the distance from ic to tb. The inside of the stock plenum doesn't have any special deflectors or flow distributors (AFAIK), and like I mentioned, there doesn't seem to be anything stopping it from behaving like a JZ plenum.
Just in case, I'll clean and flow the injectors, installing the highest flow for cylinder 6 (cause its most likely to run lean) and lowest flow for cylinder 1.
Originally posted by Steve-SST
Per4manz now have new custom plenums for RB25s.
Heya Steve how much are they charging for these off the top of your head? do you think they would do an sau discount or something if a few were interested?
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
