I choose:
lack of rear end grip
pushing to hard
You have loads of talent and have heaps of experience, I think and have heard that eastern creek can be a bit of a hard unforgiving track :domokun:
But atleast you know what the contributing factors were....its just one of those random ghey things :(
Rubbing is racing :D
ahh, you know just what to say :):)
yeah, EC can bite you hard. my friend did $80K damage to his porsche there at turn one. another friend pretty much wrote off his car there too and most track days I see one or two bad smashes. some of the walls are quite close to the track. inside wall at turn 1, and outside wall at 10/11/12 are all very close, in fact outside wall at 6/7 is pretty nasty too. hell they all are. and all concrete. :(
well I will try and drag myself out to Oran park GP this wednesday so if anyone wants to come out there is a reasonable probability of me making a fool of myself. entry is free, but must pay for drinks afterwards if I bin it again.
  • Replies 136
Do not worry Richard " It'll buff out"
I am gld it is only a minor ding as it could have been a lot worse at that speed.
Makes me remember the double 360's I did comming out of turn 4 and seeing a lot of close white walls. Luckly for me I did not hit anything.
I would leave the damaged bar on as it gives the car some cred.
Some shoe polish should buff that right out :wacko:
I'm surprised it took until page 2 for someone to say that.. although maybe it was all the "suspense" on page 1 :)
fatz calls everyone a pussy, and he's usually right. but good on you for giving it some stick - to have a scrape you were obviously pushing pretty hard and to have a minor scrape means, like already said, that you have done something right to avoid having a bigger one!! :P
Oh wow you have done it as well :)
sadly times were nothing special. Had only done about 12 laps, and only about 2 clear ones (lots of slow traffic). still good enough for 11th. It was annoying as I had just got the pressure stable-ish and was getting quicker every lap. :( I also have what I think is a badly slipping transfer case. out of corners the revs are flaring. sounds like either clutch slip or wheelspin, but it doesn't have the symtoms of clutch slip (I can't make it happen in a straight line at all) and the attitude of the car doesn't change (so not wheel spin, unless it's very slight). so I'm going to have to have a good look at that. probably would have been quicker in rwd!
I'm surprised it took until page 2 for someone to say that.. although maybe it was all the "suspense" on page 1 :(
fatz calls everyone a pussy, and he's usually right. but good on you for giving it some stick - to have a scrape you were obviously pushing pretty hard and to have a minor scrape means, like already said, that you have done something right to avoid having a bigger one!! :(
I said it on page 1!!! >.<
Who the hell reads sau on 20 posts per page! it gets to big then!
Bah, you gotta find your limits somehow. Glad it hasn't put you off at all.
I can hear a new quote now oz "GTR Baron slide out!"
Not quite, I worked on Bailey last night until he got it right.
"GTT adam spin out, but GTR Baron Smashes out, oooooohhhhhh crrraaassshhhh!!!!!!"
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
