OK well I just got my car back from *cough* toy sports *cough*
And here's the deal:
They did a smoke test and found one little hose with a tiny tiny leak, this was rectified but it still sounded like a hair dryer in the engine bay on boost :P
So they took it up to the dyno so they could run in under load and try to find the problem.
The noise is coming from the turbo and is apparently not a leak but a whine.
The factory computer is showing faults and they reset it.
Did another power run on high boost and the computer is boost cutting at 9.2psi! :Q
For some reason the computer just wants to keep boost cutting at 9.2psi!!!!!
And even after you reset the ecu it still chucks a pshyco :Q
So the verdict from *cough* toy sports *cough* the ecu is shit itself and the turbo is on the way out!
haha how coincidental that is also the most expensive diagnosis someone can give!
as for the whine, id be checking exhaust gaskets for any leaks and do a once over on all hoses. it wont cost you much to replace the vacuum lines and on a 10 or so year old car it is a good idea.
[q]as for the whine, id be checking exhaust gaskets for any leaks and do a once over on all hoses. it wont cost you much to replace the vacuum lines and on a 10 or so year old car it is a good idea.[/q]
I have checked the hoses 10 times...
And the smoke test didn't show up any leaks!
Yeah might take it to croydon
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
