hey guys im wrecking my donor car.
its an R34 GT-T.
Has everything except engine , front/rear brakes, 5 speed gone and tail shaft.
Front has damage so no panels on front or radiator support. has one LHS head light though lol.
the GTT wheels arnt available either im sorry.
the rest of the car is in tact including interior except steering wheel (airbag gone off).
ok ive started the price list .
this will grow by saturday.
im not located with the car so getting to it between work hours is hard but this weekend i will know more.
mirrors- $120 each
Doors - $350 each
Boot -$250
Door Glass (tinted) - $200 each
Door trims- $150 each
Wipers - $40 pair
Rear Screen- $300 (tinted)
Dash Cluster (60,XXXk's) - $300
Dash Pad -$200
head unit bracket- $40
Glove box- $100
hand brake (inc cable) $160
Front seats - $600
rear seat - $250
parcel shelf - $50
interior carpet - $120
tail lights - $250 each or $400 a pair.
Rear tannabe coilover (non adj 8 kg springs) -$350
Front KYB SS Stuts - $200
Rear Hicas Steer rack - $250
Rear bumper - $150
tow hooks$15 each
ABS unit - $300
ABS senders - $80 per corner
Fuel tank - $200
Quater glass - $150 each
Climate control unit $150
Air con pump $120
Brake master cylinder - $250
Manual Pedal box- $250
Roof Lining - $120
Interior light - $30
Dash Gauges (set of 3 in holder) - $180
R34 Factory Turbo (30,XXX k's no shaft play) - $550
Swaybars - $60 each end.
LHS headlight - $250
Factory intercooler - $80
Complianced Seatbelts - $50 each or $170 for set of 4
Steering rack - $200
Steering surround - $50
Reverse lights - $120
wiper motor - $50
Rear Bumper Rio - $110
Interior kick and ecu panel $70 for both
Basicly the centre console down to the shifter surround is sold so that is not listed.
i have other bits like raer trims etc. just ask and i will get pics and prices for them.
also the rear quarter panels on the car are very straight and am will ling to to chop them off if there wanted.
Availible are all the door rubber seals aswell as boot.
this list will be made larger on saturday with hopefully pics for most parts.
Edited by TasR32
https://www.sau.com.au/forums/topic/168701-wrecking-r34-gt-t/
its an R34 GT-T.
making a list of parts and prices as we speak and taking photos.
is there anything people would like?
has Factory turbo still and Tannabe coilover rear and Kyb front suspension.
cheers
benny
What the body condition like Benny eg: the complete front end???
no weather shields as far as im aware wogboy. if the are i dont where they went . will ask previous owner.
questy .....um chassis is bent a rather lot on the drivers side in engine bay.
but apparently is fixable. im not in that field so i wouldnt know. would also neer radiator support panel aswell.
GMB - what front end lol .....nah no parts or panels there. what were u after exactly.
MRO- sorry no wheels.
Floody- will chat on MSN tonite.
XXE-R32- u have a PM.
I'll take the central 3 gauge cluster if it's still available. I only need a plastic cover for one, but I'll buy the whole thing if need's be. Also, do you have the windscreen washer bottle still? I've got a gaping hole in mine! And if the gear knob is in good condition I'll take that as well, lol.
Please do not PM me ....to hard to get PM's at work.
numerous reason why i havent been online.
All parts packaged and ready to send once emails are recieved.
Please email direct to [email protected]
Parts Added- TEIN ADJ CASTOR ARMS. - $300
  • 1 year later...
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
