hey guys im wrecking my donor car.
its an R34 GT-T.
Has everything except engine , front/rear brakes, 5 speed gone and tail shaft.
Front has damage so no panels on front or radiator support. has one LHS head light though lol.
the GTT wheels arnt available either im sorry.
the rest of the car is in tact including interior except steering wheel (airbag gone off).
ok ive started the price list .
this will grow by saturday.
im not located with the car so getting to it between work hours is hard but this weekend i will know more.
mirrors- $120 each
Doors - $350 each
Boot -$250
Door Glass (tinted) - $200 each
Door trims- $150 each
Wipers - $40 pair
Rear Screen- $300 (tinted)
Dash Cluster (60,XXXk's) - $300
Dash Pad -$200
head unit bracket- $40
Glove box- $100
hand brake (inc cable) $160
Front seats - $600
rear seat - $250
parcel shelf - $50
interior carpet - $120
tail lights - $250 each or $400 a pair.
Rear tannabe coilover (non adj 8 kg springs) -$350
Front KYB SS Stuts - $200
Rear Hicas Steer rack - $250
Rear bumper - $150
tow hooks$15 each
ABS unit - $300
ABS senders - $80 per corner
Fuel tank - $200
Quater glass - $150 each
Climate control unit $150
Air con pump $120
Brake master cylinder - $250
Manual Pedal box- $250
Roof Lining - $120
Interior light - $30
Dash Gauges (set of 3 in holder) - $180
R34 Factory Turbo (30,XXX k's no shaft play) - $550
Swaybars - $60 each end.
LHS headlight - $250
Factory intercooler - $80
Complianced Seatbelts - $50 each or $170 for set of 4
Steering rack - $200
Steering surround - $50
Reverse lights - $120
wiper motor - $50
Rear Bumper Rio - $110
Interior kick and ecu panel $70 for both
Basicly the centre console down to the shifter surround is sold so that is not listed.
i have other bits like raer trims etc. just ask and i will get pics and prices for them.
also the rear quarter panels on the car are very straight and am will ling to to chop them off if there wanted.
Availible are all the door rubber seals aswell as boot.
this list will be made larger on saturday with hopefully pics for most parts.
Edited by TasR32
https://www.sau.com.au/forums/topic/168701-wrecking-r34-gt-t/
its an R34 GT-T.
making a list of parts and prices as we speak and taking photos.
is there anything people would like?
has Factory turbo still and Tannabe coilover rear and Kyb front suspension.
cheers
benny
What the body condition like Benny eg: the complete front end???
no weather shields as far as im aware wogboy. if the are i dont where they went . will ask previous owner.
questy .....um chassis is bent a rather lot on the drivers side in engine bay.
but apparently is fixable. im not in that field so i wouldnt know. would also neer radiator support panel aswell.
GMB - what front end lol .....nah no parts or panels there. what were u after exactly.
MRO- sorry no wheels.
Floody- will chat on MSN tonite.
XXE-R32- u have a PM.
I'll take the central 3 gauge cluster if it's still available. I only need a plastic cover for one, but I'll buy the whole thing if need's be. Also, do you have the windscreen washer bottle still? I've got a gaping hole in mine! And if the gear knob is in good condition I'll take that as well, lol.
Please do not PM me ....to hard to get PM's at work.
numerous reason why i havent been online.
All parts packaged and ready to send once emails are recieved.
Please email direct to [email protected]
Parts Added- TEIN ADJ CASTOR ARMS. - $300
  • 1 year later...
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
