I fitted a generic oil cooler about 6 months ago and have been a bit worried about my oil pressure.
On cold start at 3000rpm it is at, or over, 100psi (aftermarket pressure gauge)
Even when warm I am seeing around 70psi at just over 3000rpm and it's starting to worry me.
I thought it may have been the oil I was using (Motul 8100 - 5w-40) as it was getting to its 5000kms change time, so changed to a 0w-40 but the pressure is still the same.
Does anyone else have high oil pressure with one of these kits?
I'm starting to think maybe the cores are a bit restrictive causing the rise in oil pressure. i have checked all the lines and there are no kinks or anything and it is all plumbed correctly.
With a track day coming this thursday I want to sort it out beforehand if it IS an issue.
Any advice would be appreciated.
https://www.sau.com.au/forums/topic/168708-oil-pressure-question/
I see similiar oil pressure around 2000rpm when the motor is cold.
Your seeing it when warm? :S
Yes. I will have to get the oil up to full temp ~80 degrees and check the pressure then. It's a bit hard though because with the cooler it normally sits at about 70 degrees unless I am thrashing it
well i have noticed the cheap chinese oil coolers seem to have very, very small passages through them which could certainly cause high pressure.
anyway, forget the cold pressure. what is important is the pressure at operating temp (ie 80+). 5 kg/mm at 3000rpm is actually not that high oil pressure. i'd say it's about right, or even a touch low. BUT the issue here is what was the oil pressure like before the cooler? if it was lower then obviously the cooler is a restriction.
Can't comment on the pressure before the cooler was installed as I didn't have an aftermarket gauge and my factory ones is crap. When the autometer gauge reads 70psi the factory one is on or about the 3 mark :(
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
